Fukuyama Batteries
Old 11-05-2003, 02:40 PM
  #1531
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by holycow
Actually, I made that avatar specially for Jimmy. If he doesnt mind, then its cool I guess If you like, I can make you a custom one with Fukuyama and randman on it.. or Randman and fukuyama racing...
Anything.. just let me know.
oops, didn't realize you did the artwork just for Jimmy I'll PM you about one, your avatars do look cool
Randy Caster is offline
Old 11-05-2003, 02:41 PM
  #1532
holycow's Avatar
I also did Johns, Dans, Shermans, mine, Kraig's from KT hobbies, and a half dozen others I also did a new 468x60 ad banner for jimmy and dan, just waiting to see if they are going to use it
holycow is offline
Old 11-05-2003, 02:43 PM
  #1533
That's really cool, I used to be into graphic design, but dont have the software anymore to do the cool stuff..
Old 11-05-2003, 02:45 PM
  #1534
mike_Webb's Avatar
So with all you guys getting hooked up with the Putnam Power, I take it Fukuyama is not going to do Motors now???
Or once the Fukuyama Motors come out you will dump the Putnams?
I don't understand...I was looking forward to trying out your motors.
mike_Webb is offline
Old 11-05-2003, 02:49 PM
  #1535
I drive for Putnam, so for the time bieng, I'll be running just his motors, although when the Fukuyama stuff comes out, I think 90% of the people in this thread will run those.
Old 11-05-2003, 03:01 PM
  #1536
Maj. Teeth's Avatar
Default Fuku Motors
We might have a little pushback in our plans. Hopefully before Xmas but then again. It really depends on the market.
Dan
Maj. Teeth is offline
Old 11-05-2003, 03:06 PM
  #1537
Wink Thanks
Thanks for the info on the plugs. I knew it all along, and I use deans plugs for a lot of reasons. I hardwire my 1/12 because my son (11) has to lean to perfect his soldering technique. We both solder our batteries in, but my driving negates any alleged gain. Only ONE mistake driving would take away the advantage of hardwiring. I aint there yet.
Thanks Again
David Root
David Root is offline
Old 11-05-2003, 05:01 PM
  #1538
holycow's Avatar
dan YGPM
holycow is offline
Old 11-05-2003, 05:07 PM
  #1539
Default Re: Fuku Motors
Dan
That sucks... I hope that you'll be able to get them before XMas, I know it would make a nice present for a lot of people.
Old 11-05-2003, 05:28 PM
  #1540
dpaton's Avatar
Originally posted by John Fontaine
Dave - once again your knowledge astounds me. You gave us a great explanation to this subject. Now in your soldering argument, do you solder per government standards and how would you learn this trade to better reduce the resistance within solder joints?
John
I learned to solder from my dad when I was 10, he was mil-spec certified. Since then I've learned to solder to slightly higher standards, since I spent some time doing solder metallurgy work with some very wierd formulations. My solder joints probably look a littl elight on solder by most standards, but are more than sufficient, I promise.
The best way to learn to solder is to practice. There are several places on line that have good pictures of acceptable and unacceptable solder joints. The URLs escape me right now, but I'm sure Google will remember.
-dave
dpaton is offline
Old 11-05-2003, 05:33 PM
  #1541
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
I'm done racing til I can get some Fukuyama motors.
wyd is offline
Old 11-05-2003, 05:34 PM
  #1542
dpaton's Avatar
Originally posted by jkerr0043
Dave is obviously right as far as the hard wire joints having more resistance because most of us solder "wrong" and that the resistance from a bad joint is greater than the plug. BUT, when you install a plug, insted of having only one bad solder joint from ESC to battery, you have three now. One from battery to wire, one from wire to plug, then your plug connection, then from plug to ESC. You end up with three times the bad joints, and three times the resistance. Right?
If you don't solder properly, yes, that's true. If you can (and a number of people I know that race do), the plugs add insignificant resistance, and infinite convenience.
The nice thing about plugs is that they're a lot easier to solder than batteries. The amount of metal to heat is smaller, allowing the little 40-50W irons most racers have to work just fine. Batteries have a lot more mass that needs to be dragged up the thermal slope to the melting point of solder, and small irons just don't do that very well, leading to the bad soldering on packs I've seen.
For the record, even Deans goofs sometimes. I got a pigtail set that had almost 100 ohms between the red wire and the positive contact on a mating connector. Turns out the red wire wasn't really soldered, it was just kinda nearby, necessitating some solder and new heatshrink.
Moral: Nobody's perfect
But that doesn't mean plugs are bad either...
-dave
dpaton is offline
Old 11-05-2003, 05:42 PM
  #1543
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You said you have a 350 watt soldering gun, correct? I have always been told that soldering guns dont retain their heat well and don't work as well. I had a 150 watt gun that I used for a while and always got frustrated with it. It would loose heat if the slightest breeze was blowing. I went and got a $15 40 watt weller iron and it seems to work great, as long as it has a new tip. Even building batts. How much would a gun like you have run?
Jon Kerr is offline
Old 11-05-2003, 06:03 PM
  #1544
holycow's Avatar
I have experienced the exact same thing. My 40watt weller gets 2x as hot as my 250watt solder "gun". They are and always have been, total crap. My weller can sink a tinned battery par onto a tinned cell in about a second (granted it has a nice, clean tip)
holycow is offline
Old 11-05-2003, 06:18 PM
  #1545
Maj. Teeth's Avatar
Default Soldering Extremes
Want to know the extremes? but don't tell Jimmy I said this. He's got a digital weight they use for weighting in gold and jewelry and he'll weight each and every solder bit so they all have the same amount on his packs. Then with a long tweezer, he'll solder his packs together. I think he uses the brand "Kesters" for his solder and they're shiny nickel-like when it's done. Neat but waaaaaaaaaay too extreme for me. Then on his motor, he'll flatten the 12g wires and count the wires and strip the rest and solder it the same way so they're perfect each and every time. Don't even get me started on what he does to his ESC.
Dan
