Team Muchmore USA
Old 06-09-2008, 01:24 PM
  #46
Toughbeard's Avatar
my god you are pumping those batteries arent you???
I use different power supplies for my main chargers and for the dischargers.
I use a converted wall adapter that is rated for 1A for the dischargers. CTX-D is rated for 350ma and my lrp conditioner 2 is rated for 100ma power drain. so it is enough.
the reason I separetad the dischargers from the chargers is that I have read on the teck talk of TMM about the charger and discharger shorting out when the ctx-d is used for cell voltage readouts during charging with CM. (was that a ridicilusly long sentence or what)
the reason I use seperate PSus is incase the un expected happens and a PSU dies I am not left out with out a power supply... so each charger gets its own power supply.. be it 8 A or 45A... I feel more secure...
For the fans, is it OK for TMM if we replace the fans or they used these for a specific purpose...for ex... high speed extra volume fans or something like that..
Toughbeard is offline
Old 06-09-2008, 01:32 PM
  #47
Trader Rating: 90 (100%+)
Ray,
Any status on the cups for the CTXW IC? Nationals are next week and I am out of business.
RBLove is offline
  #48
gijoe64's Avatar
Trader Rating: 30 (100%+)
Ryan Lee will be on to answer your questions and get you on the right track.
gijoe64 is offline
Old 06-09-2008, 01:34 PM
  #49
gijoe64's Avatar
Originally Posted by RBLove
Ray,
Hey Muchmore Korea sent cups out UPS should have them this week, if it gets to close we can send them to the track with your name on them next day. I will contact you as soon as I recieve them. Can you send me your phone number?
We don't want you out of the race!
gijoe64 is offline
Old 06-09-2008, 01:37 PM
  #50
Good stuff. Thanks Ray and you have a PM with contact information!
RBLove is offline
Old 06-09-2008, 01:39 PM
  #51
gijoe64's Avatar
No problem and thanks I will get you going if I have to send you my cups!!
gijoe64 is offline
Old 06-09-2008, 01:47 PM
  #52
Team EAM
Trader Rating: 79 (100%+)
I need a set too! Large blue please! LOL
EA
EAMotorsports is offline
Old 06-09-2008, 03:35 PM
  #53
gijoe64's Avatar
EA
I got you Baby! How you doing EA!!!!!!!!! You better Win the Nats!!!
gijoe64 is offline
Old 06-09-2008, 04:37 PM
  #54
U mean to tell me I am going to have to pull over and let EA win??? Boy oh boy!!!!!!!!
Ray, I am not so sure I want your cups
RBLove is offline
Old 06-09-2008, 05:00 PM
  #55
Team EAM
Hell I'll just be happy to NOT be in the B main at another major race I do have the small cups on my Rheinhard edition warmers. Not sure why they came on it but thats how I got it.
EA
Old 06-09-2008, 05:59 PM
  #56
Ryan Lee's Avatar
Originally Posted by adamliehr
Hey guys, I wanted to shoot you some pics of the new Cell Equalizer coming out from Muchmore. Sorry about the bad quality, but you'll get the gist of it.
It will discharge up to six cells down to .9v at a max rate of 3amps. What is really nice is that it is nice and small and doesn't use any outside powersource like some other units.
I've been testing it on my Trinity IB4600's and it has helped keep them in great condition. If you are using NIMH batteries this is definately a tool you should try.
It should be available somtime this summer!!
"Blue" LED is a typo from my previous cell equalizer post.
I forgot to change it to red led when I copied pack equalizer's manual text. sorry! There's no blue LED on Cell Equalizer, (Pack Equalizer does).
※UNTRAY YOUR BATTERY PACK FROM THE DISCHARGER IMMEDIATELY AS SOON AS RED LED IS OFF. UNLESS, PACK EQUALIZER WILL KEEP DISCHARGE THE PACK AT VERY LOW RATE. IT MAY CAUSE SOME OF NIMH CELLS TO PERMANENT DAMAGE.
Either of Red LED will light up along the battery bars direction.
Ryan Lee is offline
Old 06-09-2008, 06:20 PM
  #57
Ryan Lee's Avatar
The reason we use high rpm fans for CTX-D2 is to check each cell's data precisely. If you do not need precise data, you can change the fans to having lower rpms.
As for Cell master charger, we strongly prohibit changing fans.
the chargers FETs generate alot of heat during charge and the high rpm fans cool down them effectively.
The fets will get hotter when you charge single cell at high amp or discharge many cells(8cells) at 10A.
so If would charge only 5-6cells, lower rpm fans may work fine. but I don't really recommend for that..
Ryan Lee is offline
Old 06-10-2008, 12:12 AM
  #58
Toughbeard's Avatar
thanks Ryan, I thought there has the be a reason for those fans.. No problems at the track, but it is really hard on married guys
Do you have any suggestions on the 4600 profile and power supply issue?
is switching power supply from meanwell good enought at 8.5 amps or we need the higher amps, or should we use a PSU such as the old rivergates... (diode and big caps coupled to a big transformer)
Old 06-10-2008, 09:47 AM
  #59
Thanks Ryan.
adamliehr is offline
Old 06-12-2008, 07:15 AM
  #60
Ray,
Received this morning. Thanks!
Rob Love
RBLove is offline
