Team Muchmore USA
#31
Ray,
You have a PM. Question regarding the Much More CTX-W IC tire warmers.
#32
I would recomend that you send your unit into our hobby services goto www.muchmoreusa.com
Yes you can discharge 5 cell packs if you goto the Muchmore Korea website it shows you how to do it properly. http://www.much-more.co.kr/tech_talk.asp
I use a liner discharge for my packs.
thank you very much for the info. I ll try to see if I can replace the 6th cell fets with the first one.. if that solves my problem I ll be fine. I live in Istanbul so it would be hard for me to send the item for repairs to US I am not sure if you would accept it at all???
#33
With no cell in slot 1, it won't start discharge. However, if your slot 1 will still "see" a cell, there is a way round it. You just need to put a cell with some charge in it, into that slot, then put pack in other slots and it will be fine. AFter it has started, you can remove the 1st cell if you wish, and it will still finish ok.
#34
Ray,
When will MM USA get the lipo balancer for the SC? You also have PM
Thanks -Paul
Thanks -Paul
#36
hello,
#37
hello,
CTX-D won't start if you don't place a cell in cell. no.1 spot as MattW said.
I will post a picture and let you know which parts should move from no.6 cell to no.1 cell. you should move two parts-the one is FET and the other one is LM324 part. then you will be able to discharge your 5cells pack.
thanks,
Ryan
#38
I am looking at getting tire warmers and just wondering if there is a difference between the platinum edition and the Mark R. ( blue) edition
#40
Detach two parts(no.6 cell) shown in the picture carefully then replace two parts in the circle of no.1 cell with them.
If this does not work, let me know. I will ask Muchmore UK if they can do because UK is closer than Korea or USA.
#41
I will let you know as soon as possible
#42
Hi, (yes it is me again )
I just received my cell masters. I got them one day befpre the race so I really couldnt use them much. I only had one unit out so I could tinker with it. I usually had problems with false peaks.
After I have seen the messages here, I checked the profile given in the tech talk section of MMR site.
What I understand from the manual is use peak charge to basically peak a battery and ctx charge to charge a fully discharged pack. Am I correct on this?
I set the CTX charge 1 (named it CTX IB4200) to the given values of
1/3 - 3000mah 7.0A Fn Tn 5cell
2/3 - 3030mah 0.2A Fn
3/3 - 5000mah 4.5A Fn T50 delta 6mv
I ll play around with delta and the charge rate of the 3rd section depending on what I need...
do we use the same profile for IB4600 as well or do you have a special profile you guys have tested for the 4600.
Since my CTX-D is out I have been using the old deans bulb discharger until the lights are dim and them I place the pack on the LRP Batt conditioner 2 with V-cutoff set to 1volts. I usually set the batts to cool off and before charging I discharge them again to 1v/cell then charge.
Is this ok?
there is some debate on between .9 vs 1.0
Is this ok?
#43
I really don't think that the .1v difference is going to be that big of a deal. Really the biggest thing that I have noticed that helps our current packs is consistancy.
I don't know much about the LRP conditioner, but MuchMore has a new balancer that should hit the States somtime this summer that is great. I posted pics earlier in the thread.
#44
Yeah I saw the pictures but couldnt locate one. now I know why
I started using 1volt because I started having cells with very low voltages that the CM give out a low cell voltage error.
I will try to find one and get it though, as I want to stay with one company. makes askng question and getting answers very easy.
question1: Why is the CM:Platinium so loud??? I have 2 and it is twice the headache :P
question2: is there an available IB4600 ctx charge profile for CM. or do we use the IB4200 profile listed in the tech talk section...
question3: I am currently using an 8.5A Switching power supply as the power source. will this cause any problems? I am currently using it but I dont know it CM is working properly. The manual suggests 24A if I remember correctly.
qyestion4: (related to 3) Is it better to use a non switching power supply. transformer, bridge diodes and caps only to supply around 12 13 volts?
regards,
Serdar
regards,
Serdar
#45
Q1: I had this same problem with my CTX-D2. Much More replaced the fans and no problem since. You could try oiling the bearings to quiet them down, but that is the only thing you could do without replaceing the fans I think.
Q2: Here are my charging profiles that I have been testing with. I don't know if they are right or wrong, but I haven't had a problem yet! Remember to take into consideration that this is for 4 cell Oval batteries that only have to last 4 minutes, but go ridiculusly fast! lol I have used both profiles for regular charging and am just trying to learn what's best.
These are for Trinity IB4600's.
CTX Charge:
Step 1/3
3500mA 6.0A
Flex off
Step 2/3
4000 7.0A
Flex off
Step 3/3
9990mA (all the way) 8.0A
Flex off
delta peak 09
Pulse Charge:
9990 mA Then I vary from 6-9 amps depending on class, track, and temp.
I like to have my cells about 120-130*f on my way to the line. I use the MM Cell Heatsink 2 for the first 10 - 20 minutes depending on weather and battery temp.
Q3 and Q4:
I'll admit I don't really know enough on this subject to give advice. I am currently using a MM 24amp ps to power 2 CTX Platinum Chargers, a CTX-D2, CTX-Batt Heatsink 2, and another cooling fan; without any problems.
Hopefully some of this may help you.
CTX Charge:
Step 1/3
3500mA 6.0A
Flex off
Step 2/3
4000 7.0A
Flex off
Step 3/3
Flex off
delta peak 09
Pulse Charge:
Q3 and Q4:
