Like Tree50Likes
Reedy!
Old 11-04-2020, 08:47 PM
  #691
SuperRC's Avatar
Originally Posted by rc pete View Post
The Torque series have a High Torque Stator, same 27414 rotor.
The winding mark (21.5, 17.5, etc.) has a single-lined border for the Standard version and a double-lined border for the Torque versions.
If you zoom enough into the pics online, you'll see the difference.
Standard: https://www.associatedelectrics.com/...c_class_motor/
Torque: https://www.associatedelectrics.com/..._17_5t_torque/
Yes, you can also outfit either of the motors with the 27415 high torque rotor.
Legend. Thank you so much for the detailed reply. I can see the lines you’re talking about.
Have you tried the high torque rotor in the standard motor? Do you lose a lot of top end?
SuperRC is offline
Old 11-09-2020, 09:45 AM
  #692
rc pete's Avatar
Yes, ran both the Standard and High Torque rotor in the Original 17.5 motor in TC. I found there to be only a small difference between them. Not enough to time or gear them differently, and the temperature was in the same ball park.
The High torque Stator makes a much bigger difference. You can see the RPM drop on the motor checker. With the stock rotor, I had to go up a bit on both timing and gearing.
rc pete is offline
Old 11-22-2020, 01:28 PM
  #693
garnt's Avatar
The S-Plus 17.5 Standard product page suggests starting with 4.60:1/35° FDR/timing for TC; are those also good starting points for the Torque version?
garnt is offline
Old 11-23-2020, 08:45 AM
  #694
rc pete's Avatar
The Torque version needs more gear. I'd suggest gearing up 2 teeth and a little more timing to start: 4.3:1 and 38°
As always, check it after a couple of minutes of running to be safe when trying a new setup.
garnt likes this.
rc pete is offline
Old 03-01-2021, 06:34 AM
  #695
Trader Rating: 28 (100%+)
Looking for a reedy 27415 HT rotor. Lmk if anyone has one in stock of om if you wanted to sell.
Thanks,
Jim
76jimmy is offline
Old 10-03-2021, 01:36 PM
  #696
Dork Missile's Avatar
Smile the need for speed
Originally Posted by davidl View Post
You might end up picking up speed with 21 degrees and the same gear. I am running that with 4.88 fdr on black carpet 60x40. The temperature should go down to the 130 range. This combination has some pretty good rip which is more important than straight line speed since the straights are not very long. Hope that is encouraging.
i am liking your discussion. we just ran our first carpet race of the season and i'm struggling for some speed in 21.5T touring car. i've been running the HT rotor but i'm at 40 degrees timing and 3.88 fdr. our straight is 90 ft long. my temps are getting high so trying a lower timing might be something to try. i will continue to watch this discussion.
Dork Missile is offline
Old 03-07-2022, 03:56 PM
  #697
DARKSIDE's Avatar
NEW Items from Reedy Power
https://www.associatedelectrics.com/...-drag-battery/
https://www.associatedelectrics.com/...al-gear-servo/
https://www.associatedelectrics.com/...ith-xt60-plug/
https://www.associatedelectrics.com/...acing-version/
DARKSIDE is offline
Old 04-28-2022, 01:00 PM
  #698
I'm also in the market for a new motor. Our track layout is loaded up with tight turns and hairpins. Surface is high grip carpet, tires are USGT spec, and the car is an Xray X4. Weight of the car all in is 1260 grams. The straight the length of a standard school gym. So I need something that will throw me out of the corners like a bullet.
Sabin is offline
Old 04-30-2022, 08:14 AM
  #699
DARKSIDE's Avatar
what class are you running?...USGT?
DARKSIDE is offline
Old 05-01-2022, 09:26 AM
  #700
It's called Scale Spec. It was supposed to be like USGT, but it's sort of morphed into a blend of touring stock/touring mod now. Scale Spec drivers are now cutting low 8 second laps, putting them smack dab into the touring mod class times.
Sabin is offline
Old 05-25-2022, 08:18 AM
  #701
DirkW's Avatar
Originally Posted by YeshuaGriffin View Post
hmmm...
What exactly are your intentions, quoting that post from 2007?
DirkW is offline
