Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-01-2007, 07:23 PM   #106
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I just picked up an Orion IB4200 six cell pack and after 5 cycles one of the cells isnt up to snuff. Self discharges really quick (down past .9v a few days after putting 2000mah storage charge into the pack) and it is the first cell to be discharged when I put the pack on a Novak Smart tray after a run. It is done about 15 minutes before the other cells. How do I go about getting it replaced?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 09-18-2007, 11:53 AM   #107
quantum's Avatar
Default motor checkers
oops
quantum is offline   Reply With Quote
Old 10-07-2007, 11:00 PM   #108
Trader Rating: 68 (100%+)
Send a message via AIM to joey
whats a good brush/spring combo for a dynasty 07 in 12th?
what kind of rollout should i try im gonna run on a nitro track.
=Joe Wright=
joey is offline   Reply With Quote
Old 10-08-2007, 06:17 AM   #109
Toughbeard's Avatar
Hi,
I have 2 questions well actually one question and 1 "I need some insight" plea...
1st the question. I purchased 3 sets of IB4200WC loose packs. pretty nice numbers (well actually way nicer than what I am using) Anyways, I built the first pack as usual. Using Muchmore bars, deans silver solder and the weller 100W iron.
unfortunately the battery is not accepting anycharge. the charger wont give any no battery warnings but the voltage stays low and the MAH indicator doesnt go up. My muchmor discharge tray has blown up (dont ask ) so I cant see which cell(s) is(are) bad.
I am kind of scared at the moment to charge them one by one because a second pack blown up on my friend on cycle (not Orion pack it was from zeppin but again IB4200WC cells)
Should I go ahead and try to charge these cells one by one? And how should I proceed afterwards. bad cells no bad cells etc...
now my plea... I actually wrote it on the electric section but I go no answers... under Brushless system question in 415MRE... My main issue is this.
the car ran slow and dumped at 3.5min mark with 76x18 GR with 2.25IR 9.4FDR (about) motor very hot, LRP tc Spec ESC very hot no thermal. Orion vortex 5.5
I finally ended up running 76x23 GR the motor was mildly warm and the esc was cool the car ran 6.5 mins and I broke the single lap record and total laps record.
So I am confused. I am used o the brushed and trying to figure out
I am thinking the FDR was too much for the motor for this particular track (medium sized track short straights with high traction ) but the car should have lauched from stand still like a rocket with this FDR right? well with the small pinion it was very slow at start up and the power came right when I needed to brake for turning.
Program was the same with all gears. and I actually tried 24 pinion on testing and the car was just faaaasssst. I actually destroyed a diff on my first try because the car launched from stand still like a.... rocket... and the diff wasnt tight enough to handle the power it received.
I have pic of the car on one of the Amains with its front wheel off the ground under power...
So I am trying to figure out why such a thing occured. is this typical of brushless systems. gear up all the way until it over heats??? but gearing down over heats it and there is not mechanical torque... I go from a 9.4FdR to 7.1 FDR (actually by mistake first then saying "oh what da hell") and the car changed from a rolling dipstick to a monster on steroids...
So my problem here is I have a fast car and I dont know why it is fast
So thanks in advance for any insight you can give me on my dilemma,
have fun...
Toughbeard is offline   Reply With Quote
Old 10-09-2007, 06:46 PM   #110
Chris08527's Avatar
Trader Rating: 16 (100%+)
guys
anyone have an ball park rollout for the peak 10.5
i am going to racing it for the first time this weekend on a big flowing track
using a t2007
thanks
chris
Chris08527 is offline   Reply With Quote
Old 10-13-2007, 11:03 PM   #111
Joe, I have a 6.5 Vantage motor that acts like the rotor is out of balance. The motor vibrates badly and makes a grinding sound when run. Is this possible? Or could it be a problem with the magnets? The rotor was pulled out and when you spin it with one end in a bearing one side of the rotor always seems to end up on the bottom. Oddly enough that side has a big white mark on it.
FastFred68 is offline   Reply With Quote
Old 10-16-2007, 04:20 PM   #112
Jack Smash's Avatar
It appears that they have forgotten about this thread
Old 10-17-2007, 07:54 AM   #113
Toughbeard's Avatar
I think because Rick left peak.... oh well...
Old 10-17-2007, 09:06 AM   #114
Send a message via AIM to adamliehr
[QUOTE=Toughbeard;3743794]Hi,
QUOTE]
As far as your question about gearing up with the temp comming down, I might be able to answer.
I know typically with brushed motors if you undergear them, they will heat up faster than if you over gear them. This probably is what happend with your brushless. I would keep going up in 1 tooth incriments and keep checking your temps and lap times. You should find somthing consistantly fast without over heating and keep it there.
adamliehr is offline   Reply With Quote
Old 10-22-2007, 07:11 AM   #115
Toughbeard:
Did it run any better for you this weekend?
Old 10-22-2007, 04:32 PM   #116
Chris08527's Avatar
hey guys
what are some temps i should be looking at with the 10.5
good temp coming off
TOO HOT
thanks
Old 10-23-2007, 06:41 PM   #117
Chris08527's Avatar
also got another question about the 10.5
i know we are looking at around a 5.0 fdr is a good starting point depending on track size
what about a ballpark rollout on foams
last year in 19t at my local track i think guys where starting around a 27.5-28 rollout
thanks
Chris
Old 10-23-2007, 08:35 PM   #118
STLNLST's Avatar
Trader Rating: 21 (100%+)
they only forgot you.....he he he
STLNLST is offline   Reply With Quote
Old 10-26-2007, 10:52 AM   #119
Jack Smash's Avatar
It's not like I need that cell now
Old 01-03-2010, 11:32 AM   #120
hndaman1's Avatar
Send a message via Yahoo to hndaman1
Questions??
I have the peak vantage 14x1 brushed motor and where can I get brushes and other parts for this thing? I cannot find any info on this motor anywhere...It came with my Sc10..
www.nutechracingusa.com
www.hexnutracing.com
www.integy.com
www.bocabearings.com
hndaman1 is offline   Reply With Quote
Where does Rick Hohwart go next? Rick Hohwart Electric On-Road 79 08-02-2007 01:51 PM
Where does Rick Hohwart go next? Rick Hohwart Nitro Off-Road 5 06-29-2007 09:08 AM
Where does Rick Hohwart go next? Rick Hohwart Onroad Nitro Engine Zone 3 06-22-2007 10:59 PM
Where does Rick Hohwart go next? Rick Hohwart Electric Off-Road 12 06-21-2007 09:44 PM
WTF Rick Hohwart Bobby J Racing Forum 15 11-08-2005 11:49 PM
