Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-20-2007, 01:19 PM   #61
I realize that laquor thinner won't take off a pre-mounted foam since they use CA now to hold it...I'm talking more of when I remount it using the old contact cement method. The few sets of tires now I've gone through since starting back up in 1/12th scale have all had problems seperating from the rim just like they did back in the contact cement days. The way I mounted mine had much less seperation issues then a factory glued tire. I guess with the larger diameter rim I could grind them down but with the normal diameter rim my tire truer will not reach all the way to the rim.
Old 02-20-2007, 01:21 PM   #62
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
You could always throw them on your truer and use sandpaper or a file to take off the foam that it wont reach.
Although mounting tires at this point is probably not worth it IMO. I dont think you will have problems with them coming off the rim normally. I havent had a Parma touring tire come off the rim in hundreds of sets.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 02-20-2007, 03:28 PM   #63
I guess...I just like to do it myself...I find all to often that factory trued tires once they get to me are no longer true. If they come with a lot of meat that's fine because I can still true them to the height I like...but if they are pre-trued to race heights I cannot.
Old 02-21-2007, 07:04 AM   #64
chicky03's Avatar
Send a message via AIM to chicky03
Our tires still come big out of the box. I am not totally for the race trued tires just because there are people who like to start their tires bigger and don't want to start them rubber band sizes. Yea it is a pain to true a lot off to get them to smaller big race size but there are a lot more guys who run bigger tires for weekly racing than smaller tires for big races.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 03-05-2007, 07:50 AM   #65
chubbspeterson's Avatar
Question.....Lee Majors or TJ Hooker?
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 03-05-2007, 08:16 AM   #66
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i've got to think about that one...
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-05-2007, 09:16 AM   #67
MikeXray's Avatar
Trader Rating: 73 (100%+)
Paul
I've been using the GRP's recently and even though I have a truer, I love the fact that they come at 58mm, I know your boxes state that your tires are made by GRP do you have a different foam formula than theirs? They feel the same to me, but I am not good enough to really say that they are exactly the same. Locally anyone who runs 64mm usually gets convinced that the "need" to true their tires to get their car to handle right
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-05-2007, 09:32 AM   #68
seaball's Avatar
i think the problem with having grp true them to 58 is in their grinding wheel. it has a very generous radius on it, and ends up narrowing the tire too much, even when cut down to 56. probably fine for asphalt, but on carpet, sidewall characteristics are paramount. unfortunately, unless they can get a custom grinding wheel from grp, they will likely come at 60.
- darrel taylor -
Old 03-05-2007, 10:27 AM   #69
protc3's Avatar
hey darrel,
what if i wanted to run a 1/4 inch radius on the sidewall?would this change the handling of my car if i was to run on gravel?any help would be appreciated.
Master Baiter
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-05-2007, 10:30 AM   #70
protc3's Avatar
hey chicky,
is the HD speed 8 more suited towards carpet? i am running this weekend at a state series race and have the standard speed 8 and the HD,which would you recomend for asphalt 19 turn?
thanks dude
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-05-2007, 11:51 AM   #71
MikeXray's Avatar
- darrel taylor -
That sounds like an insurmountable problem
Old 03-07-2007, 01:15 PM   #72
Chris08527's Avatar
Trader Rating: 16 (100%+)
parma have any plans for making a 26mm tire???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 03-07-2007, 03:42 PM   #73
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I believe the new big rim tires they have comming out for touring car will be 28mm
wallstreet is offline   Reply With Quote
Old 03-08-2007, 05:53 AM   #74
Trader Rating: 70 (100%+)
Paul the package made it for our race,thanks for the support your the man
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 03-09-2007, 04:24 AM   #75
Tornado_Racing's Avatar
Thanks for everyone who used Parma products at the Snowbirds to help you get the great results.
TC stock:
Parma Mohawk 9 out of 10 in the main. TQ and 1-8 and 10th in the main. Parma Tires 4 out of 10 TQ and second qual. 2,3,4 in the main.
TC 19T:
Parma Mohawk TQ and Win, 6 out of 10 in the main, one of them was an Alfa.
TC mod:
Parma Mohawk TQ, 4 out of 10 in the main one was an alfa that finished 2nd.
Parma tires 4th qualfier and second in the main.
1/12 stock:
Parma speed 8 and speed 8 hd. 1st place Speed 8. 7 out of 10 in the main.
Parma new Big Rim Pro 38 tires 2,6 and 10th qualifier, 3rd, 6th and 10th in the main
The Type M tqed stock rubber but that is the only result I know of in the rubber classes.
The new Pro 38 Big rim 1/12 tires were awesome. A big improvement in stability.
Paul
Don't forget PARMA foam tq'd and won the Touring Oval class as well. Thanks for all of the help Paul.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
P-Dub Racing Products Q's & A's..... P-DUB Electric On-Road 565 11-13-2007 12:37 PM
Parma Mohawks, Parma speed 8HDs, Custom Painted Parma Alfa Justin Zorc R/C Items: For Sale/Trade 3 05-23-2007 05:39 PM
Looking for MUCH MORE racing products Fastburn R/C Items: Wanted to Buy 0 06-22-2006 12:21 PM
GPM racing products Captain Harlock Electric Off-Road 10 05-03-2006 07:43 PM
PMB racing products X4 Nitro On-Road 1 03-01-2006 05:31 AM
