Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-27-2007, 07:17 AM   #196
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by TXDRacing View Post
Way to go Chickster!!!!
Man thanks for the tires and great bodies as always!!!!
My 53s were great ALL week..as long as they were below 56.5mm...LOL
See you at Johns in a couple of weeks. You and th Gate guys gonna try to come down for the Belprie Charity Race on the 9th? Be some fun racing if you guys could make it.
TXD
Cool!!
I'll see what we can do. I need a break LOL!!!
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-27-2007, 07:24 AM   #197
thanks again Paulie for everything!!!!!
Mike Pavlick is offline   Reply With Quote
Old 11-27-2007, 09:56 AM   #198
chicky03's Avatar
No Problem!!! Off to Outback Friday night!!! I can't wait
Old 12-16-2007, 09:46 AM   #199
Quick question.
The pro53's change the width of the car at all compared to the old small rim wheels?
JoelV is offline   Reply With Quote
Old 12-16-2007, 01:55 PM   #200
chicky03's Avatar
Originally Posted by JoelV View Post
Quick question.
Yes they make the car .75mm narrower at each side.
Paul
Old 12-16-2007, 06:35 PM   #201
Thank you sir.
Old 12-19-2007, 09:58 PM   #202
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default pro 53
Hello all I just received 20pr of parmas pro 53's for the Novak I ran them for the 1st time tonight at my local track ....and well I spent most the night tweaking the car,changing droop u name it but my car would spin out to the left..I cut them down to 57mm and come to find out the outside of the rim the foam was rolling off the rim on 2 of the 4 tires 1 on the frt and the r rear...our track is med to low bite and we can only use jack the gripper...the only other set of tires i ran r jaco's ...changed to parmas and the went to crap... do I need to re glue every tire ? any help will do I don't have the money to buy more and race time is getting close..thanks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-20-2007, 07:45 AM   #203
chicky03's Avatar
I can replace those tires for you at the novak race. I harldy ever glue my tires and if I do, it is on the front to take away steering. If there is rubber still atached to the wheel then it is a setup issue but if there is no rubber on the rim and you see plastic it is a gluing issue on our part.
May be you do not have enough camber? I run 2.5 in the front and 3 in the rear on my PHI with Hudy gauges. What car are you running? Let me know so we can get it figured out.
Paul
Old 12-20-2007, 10:17 AM   #204
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
i think he runs the schumacher
is the reason your running that much camber just cause of the bigger rim tire ?
wallstreet is offline   Reply With Quote
Old 12-20-2007, 01:59 PM   #205
Korey Harbke's Avatar
Seems to give more grip overall, and it help the edges not peel.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-20-2007, 02:40 PM   #206
Paul
this is how it looks.... I will try more camber
Parma/PSE Racing Products-dscf0824.jpg
Old 12-20-2007, 02:42 PM   #207
Mr. McGoo's Avatar
Holy Guacamole!!!! What did you do to that tire....it was just a poor defensless piece of plastic and foam!!!!
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 12-20-2007, 03:00 PM   #208
I'm running your setup and it did this
Old 12-20-2007, 03:01 PM   #209
Mr. McGoo's Avatar
Touche'!!!!!
Old 12-21-2007, 07:14 AM   #210
chicky03's Avatar
WOW thats pretty bad. Was the by any chance a cyan or magenta or did they both do that?
I know at Scotty's we normally have to run more camber than normal but I would start with 2 in the front and 2.5-3 in the rear and see what happens. Seaball will be at the race to help you with setup should you have more problems.
Wallstreet- When I first started running the Phi the tires started to cone out so I kept adding camber until it was pretty flat. That is where I ended up. On low traction my tires camber in now and on high traction they wear pretty flat since the car rolls more.
Paul
P-Dub Racing Products Q's & A's..... P-DUB Electric On-Road 565 11-13-2007 12:37 PM
Parma Mohawks, Parma speed 8HDs, Custom Painted Parma Alfa Justin Zorc R/C Items: For Sale/Trade 3 05-23-2007 05:39 PM
Looking for MUCH MORE racing products Fastburn R/C Items: Wanted to Buy 0 06-22-2006 12:21 PM
GPM racing products Captain Harlock Electric Off-Road 10 05-03-2006 07:43 PM
PMB racing products X4 Nitro On-Road 1 03-01-2006 05:31 AM
