Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 05-19-2008, 11:44 AM   #1456
How do you get a runtime close to an hour??
jawa is offline   Reply With Quote
Old 05-19-2008, 12:34 PM   #1457
rockstar81's Avatar
If I had to guess a lower kv motor and a 6000+ mah lipo
rockstar81 is offline   Reply With Quote
Old 05-19-2008, 01:33 PM   #1458
Trader Rating: 32 (100%+)
Discharge at 1C
gulio is offline   Reply With Quote
Old 05-19-2008, 03:34 PM   #1459
well i drift, with plastic pipe tyres, so theres really no strain being put on the motor, steering servo, or drivetrain. I run a vortex 7.5 with 4700 & 4800 lipos. racing is completely different to drifting, more strain being put on the motor/steering servo/drivetrain. If i strapped rubbers to my drifter, then i would be pulling 15min runtimes...
Drift Demon is offline   Reply With Quote
Old 05-19-2008, 03:56 PM   #1460
streetracer745's Avatar
Send a message via AIM to streetracer745
yes i can go to the same place, and run probably twice as many laps while drifting than i can with grip setup. this is all in a yokomo with an LRP system and 4500mAh nimh. obviously not CC but still brushless and a high powerd one too. drifting doesnt take near the power pulled from the motor. it works half as hard...
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-19-2008, 04:23 PM   #1461
theprocess's Avatar
Anyone used an Orion/Peak Racing motor sucessfully with the new firmware?
Hooked up with all stock settings. Wired A tab - White wire, B tab - Black wire and C tab - Red Wire. All the motor does is cog. Wires got hot so I pulled the plug right away before anything over heated.
Any ideas?
theprocess is offline   Reply With Quote
Old 05-21-2008, 10:45 AM   #1462
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Well just a little repost on how my Sidewinder system has been working for me over the last 5 months. Everything has been excelent and has never missed a beat til this weekend. Found the problem was simply the old connectors where worn out (these where not the new Castle bullets, these where the stock ones) which I knew would happen but wanted to see how long they would last for me. I got 4 months out of them. I ended up just cutting off the bullets and soldering everything wire to wire with some shrink tubing over each solder joint. Works flawlessly again.
Been running mainly the 4600kv Mamba motor except for 2 weeks with the 5700 motor in. My 4600 motor is coming up on 9 months plus of running and still works like the day I bought it. Its never been overgeared according to temperature checking or has the speedo. All in all the Sidewinder system has been totally reliable in my 2wd mod buggy.
ST Racing Concepts (STRC)
Old 05-21-2008, 10:47 AM   #1463
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
Any ideas?
try putting the white (middle) wire on the middle post on the motor.
chewiefttc4 is offline   Reply With Quote
Old 05-21-2008, 07:02 PM   #1464
theprocess's Avatar
Still no go. All the motor does is stutter, even at full throttle.
Old 05-21-2008, 07:35 PM   #1465
maybe you have a burnt phase
try start power high. timing lowest.
Old 05-21-2008, 11:49 PM   #1466
Default motor maintenance
What kind of maintenance did you do on the 4600? I just ordered a 4600 sidewinder and a 7700 mamba. I am new to brushless.
Old 05-21-2008, 11:58 PM   #1467
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Check this out http://www.rc411.com/pages/howto.php?howto=17&page=4
Drift_Buggy is offline   Reply With Quote
Old 05-22-2008, 05:58 AM   #1468
wyd
Tech Legend
wyd's Avatar
So far only maintenance I have done is to take it out of the car and just wipe it off with a clean rag. I have not oiled the bearings at all since the end bearing is covered by the decal so no dirt gets in and end bearing where the pinion goes on is covered by my gear cover it don't really get too dirty. The bearings have factory grease in them. I never spray ouot bearings I leave the factory grease in them and maybe add a drop of oil from time to time depending on the condidtions I run it.
Just keep it geared that the motor is under 175 degrees and you shouldn't have many issues.
Old 05-22-2008, 06:56 AM   #1469
theprocess's Avatar
I tried start power at high with normal and high timing...still nothing.
"burnt phase" what exactly is that? motor or esc problem?
Old 05-22-2008, 08:33 AM   #1470
wyd
Tech Legend
wyd's Avatar
I ran the Orion 13.5 with my MM. It wasn't perfect but once it got moving it was fine until I would stop and then it would hesitate til it was moving and it would be fine. I will have to look at how I had it wired up.
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
