Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 05-08-2008, 03:55 PM   #1441
rockstar81's Avatar
Originally Posted by Drift Demon View Post
the orions shouldnt really be having trouble because they're designed for use with sensored OR sensorless ESC. it could also come down to the motor wiring setup you using, fiddle around with them & see if it fixes it. Im usin' an orion 7.5, mamba max, still on the oldskool firmware & she has never missed a beat!!
I've heard people have had better luck w/ the faster motors, no experience here though. I tried switching wires, double checking solder joints, and all the possible timing/start power combos possible. I hate to do it but for Super Stock I will just have to run an evil system.
rockstar81 is offline   Reply With Quote
Old 05-13-2008, 11:06 AM   #1442
Default Please advise : 6900KV or 7700KV with Xray T2?
I am considering a MM system for an XRAY T2 2007 to be used on outdoor on road track. Which one of 6900KV and 7700KV would you recommend to keep up with the nitro cars? Our track has almost only nitros and we have a hard time to follow with our few electrics. Thanks.
jawa is offline   Reply With Quote
Old 05-13-2008, 04:08 PM   #1443
A very good 2S Lipo with a 7700 kv. The problem is not the system but the guy (you) and tires. Such system can spit over 500 Watts, It serious stuff
Please check out those movie from a French guy running a Xray T2 on large track with a mamba max, He use both 7700 kv motor (CM36) or a 6200 kv from Tekin(*), but he use 3S lipo in some cases
http://www.dailymotion.com/wasp94/vi...armousets_auto
If you really need some extra speed Tekin does have an insane 9000 kv motor.
* very close in term of design and performance imho, because i own a Castle creation cm36 4600 kv and a Tekin 448 (4800 kv) I can tell you that there are roughly egal. Tekin motor just look more "PRO" with soldering tabs and unscrewable endbell for maintenance.
Mister-T is offline   Reply With Quote
Old 05-13-2008, 08:07 PM   #1444
Joe Ford's Avatar
Send a message via AIM to Joe Ford
3s lipo with the 5700 is the fastest setup...65mph EASY in a light onroad...you'll KILL nitro guys if you can handle your car. Not sure if you have a voltage limit or not though. If limited to 2s go with the 7700. Start small on gearing and work your way up a few teeth at a time...either take teeth off the spur or add to the pinion, but not both at the same time. The motor has to stay below 200F. Final drive ratio of 12:1 is always a good starting point.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 05-14-2008, 04:44 AM   #1445
Default MM with XRAY T2
Thanks. I am actually using 4600 NiMH packs (6 cells). What difference will it make with respect to Lipo?
Old 05-14-2008, 11:57 AM   #1446
Joe Ford's Avatar
Lipos have a higher energy density...that means you can get say a 2s 4800mah lipo battery, and have it weigh about the same as 2 or 3 Sub C NiMH cells. Lipos also hold their voltage better than NiMH...the last part of your run is almost as fast as the beginning...NiMH you just go slower and slower and slower until it stops. The downsides to lipos are they demand respect to use them. You have to follow certain guidelines about charging, storing, etc or you can get bit. Seen far too many lipo fires in my days here at the Castle. A great option is A123 batteries. They're li-ion cells. Slightly lower voltage per cell than lipos, but you can fast charge them, they don't catch on fire, etc. You still need a special charger for them just like the lipos though.
Joe Ford
Product Specialist
Castle Creations
Old 05-14-2008, 02:37 PM   #1447
Default Brushless on 1/12th scale
On the same track, I am thinking of trying my 1/12 (RC12L3 with 6 cells NiMH) with a 4600KV. Anybody tried this? What kind of speed should I expect?
Old 05-14-2008, 02:52 PM   #1448
streetracer745's Avatar
Send a message via AIM to streetracer745
can you fit 6 cells into a 1/12? and the downsides to A123 are the fact that they are only 3.3v per cell. so some systems cant take 9.9v and 6.6 isnt enough to keep up nitro on the 7700. but you could possibly build a 9.9 and run the 5700... that would be almost identical to a 7700 with 7.4 lipo.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-14-2008, 03:13 PM   #1449
I am currently using the 1/12th with 6 NiMh cells of 4600mah capacity. Since the MM 4600kV is said to be equivalent to a 12T brushed I would expect a very high speed with that setup and long run times.
Old 05-15-2008, 07:56 AM   #1450
Default Q about programming
so I enter manual programming mode.
Throttle yes
brake no
I am trying to get to section 7 to program the cutoff for a lipo.
I want to brake, 6 times and I will hear 7 tones to indicate section 7, correct? then I throttle to enter? Brake to step through the sub-sections? but the number of tones will indicate what section I'm in, correct?
cesspool is offline   Reply With Quote
Old 05-15-2008, 08:15 AM   #1451
Joe Ford's Avatar
Give us a call with the car in front of you...we'll walk you right through programming over the phone. 913-390-6939 and hit 1 for tech support.
Joe Ford
Product Specialist
Castle Creations
Old 05-15-2008, 10:42 AM   #1452
Done! Thanks Joe. I didn't catch the name of the guy that helped me, but he was a huge help.
Phil
Old 05-15-2008, 01:40 PM   #1453
Joe Ford's Avatar
Our pleasure.
ATTENTION Anyone having issues downloading the latest version of Castle Link v3.051 please email me at [email protected]
We think we have a fix but need more people having issue to test it for us.
Joe Ford
Product Specialist
Castle Creations
Old 05-17-2008, 03:29 PM   #1454
What do you recommend for measuring motor temperature? Is a fan a good thing to use to keep it cooler?
Old 05-18-2008, 01:34 PM   #1455
If your using the system for more than 15mins a run, i would strap a fan to the esc & motor, but if your only using it for 5mins a run, maybe just a fan on the motor. Because i drift with mine & my runtimes are close to an hour, i use a big 40mm fan mounted above the motor, works a treat & i can notice the difference in using the fan & not using it...
Drift Demon is offline   Reply With Quote
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
