Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 04-30-2008, 08:27 PM   #1426
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
cut the factory wires about 1/4 inch above the board. and then use them as soldering posts..
chewiefttc4 is offline   Reply With Quote
Old 05-01-2008, 02:53 PM   #1427
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Originally Posted by streetracer745 View Post
so how are we supposed to change out the wires? and will the first batch of mamba monsters have presoldered wires? if so what guage are they?
You're not. Soldering on our controllers voids the warranty...always has, always will. We replace wires for $15, and that includes shipping back to you. The first batch of monsters have wires soldered on since our motors are not done yet. They'll be 10ga wire, and have 6.5mm gold connectors for the ESC and motor connections.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 05-02-2008, 04:41 PM   #1428
streetracer745's Avatar
Send a message via AIM to streetracer745
will the mamba monster come with connectors for the motor? i know it has wires already but i dont see 6.5mm connectors anywhere...
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-03-2008, 11:39 AM   #1429
Super_Roo's Avatar
Castle have the 6.5mm bullet connectors listed on their web site for $6.99, so any hobby shop that sells the Castle gear should be able to get them.
http://www.castlecreations.com/products/ccbullet.html
Our lhs hides them behind the counter in the battery section.
Super_Roo is offline   Reply With Quote
Old 05-05-2008, 03:21 AM   #1430
mutley001's Avatar
Hi Guys,
Had a look through the thread to try to find a solution to my problem, but couldn't find what i was looking for so here goes:
I run a Mamba 25 in my xray M18t and works great on a fully charged battery, but at the end of a run as the battey drops of it seems to lock full forward, reverse, steering left or right (whatever the last input to the controller was) which can lead to some amazing and expensice crashes.
I'm using Futaba 2.4ghz radio gear (3tcs)
Is it a setting I have overlooked? or something wrong with the speedo?
Unfortunately I don't have the link cable so have to set it manually and not always sure I get it correct!
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 05-05-2008, 11:57 AM   #1431
vinsedprince's Avatar
Default mpower
M power
vinsedprince is offline   Reply With Quote
Old 05-05-2008, 12:06 PM   #1432
Originally Posted by mutley001 View Post
Hi Guys,
Paul
set your failsafes. sounds like they are set to hold instead of set.
they hold the last known position. or it can go to a pre"set" value
my nomadio gives you the choice on each channel weather its hold or set im not sure if your futaba is the same and i dont think the mamba 25 has radio priority circuitry. that way instead of sending power to the motor it sends power to the reciver so you maintain control
Old 05-05-2008, 01:10 PM   #1433
Joe Ford's Avatar
streetracer...the Monster Max will come with the 6.5mm connectors you need for your motor. I believe we're even giving you 10ga wire until our motors come in. Once our motors come in they'll already have extra long wires, and 6.5mm connectors so you can just plug into the ESC.
Joe Ford
Product Specialist
Castle Creations
Old 05-06-2008, 06:31 AM   #1434
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
We have some in at the shop I help out at. They are huge. No pwer will be lost here.
ST Racing Concepts (STRC)
Old 05-06-2008, 08:08 AM   #1435
ta_man's Avatar
Trader Rating: 151 (100%+)
Default Sidewinder Motor Limits
I have a question on motor limits for the Sidewinder running other than Castle brushless motors:
1) What is the motor limit for brushed mode when wired for foward/reverse operation?
2) What would be the motor limit for the Novak or other similar (LRP, etc) brushless motors (low end limit, like a 5.5 or a 4.5, etc)?
ta_man is online now   Reply With Quote
Old 05-06-2008, 09:15 AM   #1436
rockstar81's Avatar
Default Novak?
Has anybody out there ran a 13.5 Novak on a Mamba Max controller, and if so what kind of results did you get? Thanks
rockstar81 is offline   Reply With Quote
Old 05-06-2008, 01:36 PM   #1437
Joe Ford's Avatar
19T limit in forward/reverse, no limit in forward only wiring.
Go by the kv of the motor. Whatever they sell that's closest to 5700kv and does 2s lipo, or 4600kv and does 3s lipo.
Joe Ford
Product Specialist
Castle Creations
Old 05-06-2008, 03:36 PM   #1438
wyd
Tech Legend
wyd's Avatar
I seen one of the local hobbyshop owners run the Mamba with the Novak 13.5 and while it does work it hesitateson initial hit of the throttle. Once it gets moving it runs perfect. If you come to a stop and start again it will hesitate once again til it starts moving forward and then it is fine. Its not perfect.
The Novak seems to do just what my Orion 13.5 does and the Trinity Duo 13.5.
Old 05-06-2008, 04:34 PM   #1439
rockstar81's Avatar
Yeah I tried a Trinity Duo also and it was worse than this Novak is Just trying to get in the 13.5 game.
Old 05-08-2008, 02:40 PM   #1440
the orions shouldnt really be having trouble because they're designed for use with sensored OR sensorless ESC. it could also come down to the motor wiring setup you using, fiddle around with them & see if it fixes it. Im usin' an orion 7.5, mamba max, still on the oldskool firmware & she has never missed a beat!!
Drift Demon is offline   Reply With Quote
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
