Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#1293
about the new sidewinder micro speedo, is the specs different in any way compared to a newly bought mamba25? (bought one last month)
or is it just the sticker that is different?
#1294
Just a quick question, will Castle ever put solder tabs on there 1/10 motors??
#1295
When will the 1/8 conversion mamba max and Nue motors come out?
I've been delaying my E8 conversion for this. I have read alot of good comments about the Castle mamba with Neu motors being used in 1/8 conversions and would not like to get the Novak one.
How much would it be?
#1296
i your sick of waiting, i would suggest buying a Mamba Max ESC & a Neu motor, & when the MMM comes out you can always sell the MM & get the MMM esc only...
#1298
can somebody post pics of how you mounted and wired everything to your kit..
tips from manual were :
to shorten the wires.
avoid contact of antena to wirings.
i test run mine and i'm getting GLITCHY after few meters and some kind of a EPELEPTIC effect on throttle and steering.
#1299
Tech Legend
Trader Rating: 51 (100%+)
If your radio is an AM version you are going to have more chances of glitching vs an FM based radio. Gltiching can be caused by numerous things so it is hard to know exactly where to start with you problem. Maybe a pic of your setup could help as then I can shoot you some ideas to try.
I only have my offroad setup that I can post for you. 1st pic is my X-6 with Mamba Max setup and the 2nd pic is my Academy GV2 with a Sidewinder Prototype (Had solder posts) but the new Sidewinder the wiers are soldered to the board. Not sure if they help you or not but will try it out.
#1300
thanks for the reply.
i'll post pics. i got it mount with my tt01. space is kind of a problem. i see you ROLLED the antena wire? or is it just excess portion of it?
i'll try to fully charge my batt (gp3700) to and see.
any other suggest are welcome and will be appreciated !
#1301
Tech Legend
Other things it could be in no certain order: Bad servo, bad crystal, wires to crossed up, use two pieces of servo tape under your receiver, bad battery (or low voltage), voltage dropping too low going to the receiver, antenna too close to other wires (normally not a problem with FM but can be more of a problem with AM).
#1303
Hello, my MM ESC suddenly stopped making the ringing noises when it starts up. When I throttle it, it completely cogs up. Anyone know if the lack of ringing noise means anything? Thanks in advance.
#1304
thisguy, that has started happening to me recently. I ended up unplugging the ESC from the RX, and it would start properly, then I plugged ESC into RX and was able to drive away. Also, switching battery fixed it, which is really weird b/c nothing was wrong with that battery.
#1305
I am using a spektrum SR3000 receiver and dx3r transmitter.
