Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 02-12-2008, 03:33 AM   #1231
DARKWAV - i had the same problem, & it turned out to be the on/off switch, yep, thats right...
It seemed that when in the 'on' position, it was not making proper contact/connection. when it first happened i fiddled with the switch to get it in a position where it wouldnt do it, but where i drift is a little bumpy so the switch moved & started glitching again, so my fix was simple, remove the on/off switch & solde the wires together!!
Drift Demon is offline   Reply With Quote
Old 02-12-2008, 09:53 AM   #1232
Registered User
I'm thinking about getting a sidewinder combo for my B4. Whats this i hear about how you can program it without actually needing the PC cable? Manual programming or something?
You technically can, but it's a pain in the rear to do and in some instances can be flawed. We bought a Sidewinder ESC yesterday to run in a crawler and we cannot get it to go to the step where you select the motor type, so you cannot change it from brushless to brushed mode making the ESC useless until we get a castle link or find someone local with one.
It's worth every penny to get the castle link and avoid the headache of having to do it manually.
Desolas is offline   Reply With Quote
Old 02-12-2008, 10:06 AM   #1233
DARKWAV's Avatar
The sidewinder does come with a rather wimpy on/off switch. I have thought about replacing it with something more substantial. However I don't think that is the problem.
I had almost two full good high power runs yesterday. Jumping and tumbling and whatnot. Just before these runs I had removed the barrel spring from the suspect connector to make it wider in the center and narrower at the ends in hopes of improving contact on the male and female connectors. So that helped quite a bit but only temporarily. By the 3rd run, even after time for a cool-down the car didn't have quite as much punch, and evenually was glitchy again.
My last effort after that was to put some solder around the base of the spring. I only had time to see if the car would run up and down the street...it did and was fast but it didn't feel like it was really getting full power..that's not really a great test though as I need to bang it around in the dirt. Still I'm hoping at least this will work as an interim solution
I'm going to try the CC Bullets next. Have to order them first though.
DARKWAV is offline   Reply With Quote
Old 02-12-2008, 10:14 AM   #1234
DARKWAV's Avatar
I haven't tried stick programming with the Sidewinder yet. I noticed that the firmware updates on Castle's site indicate that the newest firmware (1.17) fixed this defect in addition to a few other items:
"Bug: stick programming would not allow you to change the motor type"
I did get the Castle Link and found that my Sidewinder originally had 1.15 firmware on it before I used the Castle Link to update it to the 1.17 version.
Old 02-12-2008, 12:26 PM   #1235
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Shoot me an email with your full name, mailing address, and phone # and we'll get a replacement Sidewinder out to you. [email protected]
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 02-14-2008, 05:30 AM   #1236
RAP66's Avatar
I'm moving my MMax system to my 4wd buggy. As a precaution I would like to add a cooling fan to the speedo. Does anyone have pics of a MMax with a cooliing fan attached?? and where is a safe place to get 5v to power it?
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 02-14-2008, 05:38 AM   #1237
stickman310's Avatar
Send a message via MSN to stickman310
Whats the lowest turn motor the Sidewinder can run for both brushed and brushless? If this can run and stay cooler than my Sphere (heats up like crazy for some reason) then I might switch that with my Sidewinder when i get it and run it with my Novak 6.5 with bonded rotor in my BJ4WE. Would that work?
stickman310 is offline   Reply With Quote
Old 02-14-2008, 07:03 AM   #1238
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
You really don't need a fan on a Mamba Max as it is more durable and can take more heat than anything on the market. It is designed to be overkill, which isn't a bad thing at all. If you feel the need for a fan I normally run mine thru the receiver in the open 3rd channel slot.
ST Racing Concepts (STRC)
Old 02-14-2008, 12:40 PM   #1239
RAP66's Avatar
Thanks! I just want one there as a security measure.
Rich Pedro
[email protected]
www.rcracing.com
Old 02-14-2008, 05:46 PM   #1240
wyd
Tech Legend
wyd's Avatar
No problem. Go for it then.
Old 02-14-2008, 07:55 PM   #1241
streetracer745's Avatar
Send a message via AIM to streetracer745
so any release dates for the monster max? im dieing to get my hands on one! do yall have one that will be setup to run good on a 3s?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 02-15-2008, 02:28 PM   #1242
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
well at least its friday, big race 2mrw and as luck would have it, my replacement speedo came in the mail. i just thrashed for the last 2hrs installing, wiring, and preppin car to at least run b4 puttin it on the board for 2mrw. and thank you castle...
FOR ANOTHER DEAD SPEEDO!!!!!!!!!!!!
What is the deal man, did u send some other person's warranty unit, this thing does the same thing mine does!!! i then tried to plug it into castlelink to see if there was a parameter that was a miss or backwards, and surprise, i cant get in - comm error. your gettin both of them back, when i get a 'working' unit back, it will be for sale at a bargain price for the 1st lucky buyer. My mamba max will be sold off asap as i do not want to deal with this crud any longer.
-Disgruntled
UltegraSTI is offline   Reply With Quote
Old 02-15-2008, 02:52 PM   #1243
mooony's Avatar
-Disgruntled
If I was you I would check the computer.
Ronald
mooony is offline   Reply With Quote
Old 02-15-2008, 02:55 PM   #1244
Registered User
UltegraSTI's Avatar
like i said, it didnt work before it saw my PC. the same PC that has no issues w/my Max's.
Old 02-15-2008, 04:50 PM   #1245
Registered User
UltegraSTI's Avatar
my apologies in advance for the abrasiveness of the post, just tired from a long wk and i wasnt prepared to deal with this added frustration.
R
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
