Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#91
Originally Posted by jasonb
Are your CMS 36 series motors fitted with bonded or sintered rotors?
Jason
Jason
Later,
#92
Originally Posted by Glowster21
Ran mine in brushed mode the other day and I had a strange problem. The ESC seemed to cut out 3 or 4 times in the middle of the straight. Anyone else had issues like this?
Later,
#93
Hi all,
anyone has any kynd of problem when running Mamba Max and 5700Kv motor, when the punch is set to more than 30% with IB 4300 cells?
cheers
Sampaio
cheers
Sampaio
#94
Originally Posted by sampaio
Hi all,
cheers
Sampaio
cheers
Sampaio
If you are having a problem list it here and we will help you get it resolved.
Later,
#95
Magnets in all of our motors are sintered.
#96
Hi I just bought a mamba max with a 5700 motor. And I was wanting to know what would be a good gear ratio to start at or a pinion on a 78 spur. I drive a Yokomo BD Thanks
#97
Always start with your biggest spur and smallest pinion and work your way in a few teeth at a time (either drop teeth off the spur or add teeth to the pinion). As long as the motor doesn't get above 200F you're good to go.
#98
Originally Posted by CRASH
What kind of problem? You should not have any problem at all running IB4200s.
Later,
Later,
so the problems is when you setup the punch control to higher than 30% with IB 4200, the motor not run perrfectly..... it's show a small movement than stop with a high frequency...... it's freak because I try to put other motor, less power, to chek if the problem was the ESC, the motor run fine.
any ideias?
thanks
Sampaio
#99
#100
Hi
Any chance mamba motors being IFMAR legal in the near future?
Thank in advance
Thank in advance
#101
Originally Posted by Itchy
Hi
Thank in advance
Thank in advance
Later,
#102
Have you guys had anyproblems with the motor cutting out, then give it a kick and it works? the motor is the 7700 and I run it in truck and onroad.??
thanks
thanks
#104
thanks
thanks
Later,
#105
Originally Posted by JSJ Racing
Can you tell me the size of the motor screw? I am mounting one in a Scalpel with the stock motor pod and one of the screws is to short.
Thanks.
Thanks.
Later,
