Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 11-21-2007, 01:32 PM   #976
barber's Avatar
Originally Posted by Joe Ford View Post
No, there's a separate board for the Castle Link that plugs into the receiver plug on the Mamba 25...you'd need it to plug the Mamba 25 in. It doesn't come with the Max.
ygpm joe
BARBER SHOP RACING.
Hara Cyclone Edition,MAMBA 7700KV,Spectrum,
Mazdaspeed 6 Painted By McGoo Creations,
JR Z1,Orion 4300Mah,Ib 4200Mah,Ice,Rp,Trinity.
Race Prepaired & Driven By TEAM DRIVER (BARBER)
barber is offline   Reply With Quote
Old 11-21-2007, 04:32 PM   #977
well, lets say then i dont have posibility for USB programing and i dont want to buy more stuff...
i did some tests today , when i connect the battery, the mamba 25 makes 1 ring, waits a little and then 2 rings in a row, then it shows a RED solid light , no yellow
i make the calibration , all looks right, at the end , finish with the 4 rings for the neutral position calibrated, wait 1 second and 2 rings more to say its armed, then RED solid light again
i push the gun and red light start flashing but no motor movement, i push brake and red light flashing but no motor movement, when i leave the gun alone in neutral position , it shows red solid , should it be yellow? i dont really remember what light was for neutral when the ESC was workign right.
i also checkd the transmiter for not zero trim on throtle , it was indeed not in zero , but i changed to zero and repeat calibration... same thing , the motor is like dead ....
please HELP!
DrKucho is offline   Reply With Quote
Old 11-21-2007, 06:53 PM   #978
Nitrobuggies's Avatar
Hey guys.
I got a Mamba 25 Speed Controller here. It is connected to a Trinity Mini Cobalt Brushless and does not seem to work.
The Servo works fine, and everything. But when i try to accelerate or use reverse nothing happens. I have followed to instructions in the manual, and done step 3.1 i believe it is many times, and done it exactly to how the manual says. After setting the speed controller i still get no motion from the motor. I connected a brand new Dynamite C4 8000kv to it and same thing. So i checked both motors on another cheaper speed controller and it worked instantly.
What could it be???
Also could someone please tell me what wire does what on the Trinity motor. Which one is Positive, Negative and earth. I believe the Red is Positive, Green is earth and Yellow is Negative. Is this correct????
Nitrobuggies is offline   Reply With Quote
Old 11-22-2007, 12:02 AM   #979
Super_Roo's Avatar
DrKucho - Try reversing the throttle channel on your radio and then recalibrate and see if that works. Also if your radio has a 70/30 switch for the throttle trigger switch, make sure its set to 50/50 and if not recalibrate.
Super_Roo is offline   Reply With Quote
Old 11-22-2007, 03:27 AM   #980
Originally Posted by Nitrobuggies View Post
Hey guys.
What could it be???
you may have same problem than me, please describe how lights do when you throtle, reverse and stay in neutral
about the cables in any BL motor , what i know is : it doesnt matter which one is which one, just connect them to any cable coming from the ESC and if the motor spins reversed, just swap two cables and it will work fine , that's all you have to know ...i belive
Old 11-22-2007, 03:40 AM   #981
thanks i will check the reverse thing , but it shouldnt be the reason as it was working before ....
my radio is 50/50
Old 11-22-2007, 03:08 PM   #982
did the reverse test but didnt work , i also ccconected the mamba 25 to a diferent car with diferent receiver and controlled by a diferent transmiter, the thing wss doing the same , calibrated for new transmiter but problem still there
im doing all these things but i dont really see the point of the problem in the transmiter settings, it makes no sense, because the calibration is exactly for that , to adapt to your radio . so if the problem is a wrong setting in the transmitter, calibration should fix it , but it is not ....
help .... help , HELP !
Old 11-22-2007, 09:24 PM   #983
Mooshu Beef's Avatar
Hey Joe, will the sidewinder have a brushed profile as well? Or will it solely be a brushless system?
I have a GTX that I am going to sell, and another ESC that I can get a good deal on, but I don't want to buy it if I can get the Sidewinder ESC for $80...
Aahh... brushless conversion is so tempting.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 11-23-2007, 01:22 PM   #984
i found what was wrong.... my battery was discharged !!!!!
i think the red light instead the yellow one is saying that the lipo cutoff is not allowing you to thortle, if this is correct , it would be a good idea to include this in the manual
as well as correct the mistakes on the programing guide steps , cause it says rings in two steps but it should say beep, and some other wrong steps order in the calibrating secuence ...
sorry about my stupidity , i should check the battery before but it should not be discharged thats why i didnt think about this
still not 100% sure the problem is gone cause battery is still charging , but i think this is it
Old 11-25-2007, 05:29 PM   #985
Well I thought about your dead battery thing today when my car was not working right When I hit the throttle my car would slow down and I tried everything to fix it Then after like 45min. I put my other LIPO in and low and behold the car was just fine I must of hit the discharge instead of charge and well !!! it said it was done!!!! so I put it in my car.!!! Now I know what happens when the LIPO cut off works like its suposed to, I set mine at 6.5 so no harm done. I just thought I would share that with you .......Mamba max rules......... even when you make mistake's.
Lazer Guy is offline   Reply With Quote
Old 11-26-2007, 08:33 AM   #986
Trader Rating: 93 (100%+)
Default Cooling fan
Hi I'm running a mamba max 7700 In a dirt oval car and when i gear it hard the speed control gets hot from no air getting to it. I checked it after a run and it was 290 degrees! Can someone give me an idea where to buy a cooling fan to put on it? I have seen them before but can't find one now. Thanks
latemodel13 is offline   Reply With Quote
Old 11-26-2007, 07:15 PM   #987
barber's Avatar
nexus racing look under brushless motor acc i am using the intergy one.
BARBER SHOP RACING.
Old 11-26-2007, 07:54 PM   #988
Joe Ford's Avatar
Send a message via AIM to Joe Ford
I've seen my MM's at 275F+ quite often...as long as the motor stays below 200F and your ESC isn't thermaling you don't HAVE to use a fan. If you'd like to though, it won't hurt anything.
Yes, it will be brushed and brushless.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 11-27-2007, 09:26 AM   #989
Island Losi's Avatar
Damn i guess the esc is 'Built Ford Tough'
Yokomo|SpeedPassion|McgooCreative|TeamOrion|FusionPower|Futaba|Spektrum|RP|Trinity|Protoform
Island Losi is offline   Reply With Quote
Old 11-27-2007, 09:28 AM   #990
barber's Avatar
it would not last long at those temps.
BARBER SHOP RACING.
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
