Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#706
hi everyone...will these work with my mamba max 6900kv?
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=010
thanks all
thanks all
#707
thanks all
thanks all
I use Premium power 7.4v 2sp 4700mah 20C+ packs.. get about 15 to 18 mins on a 5700. http://rc-mushroom.com/product_info....ducts_id=11630
Plus Lipos are something u dont want to cheap out on trust me.
#708
Tech Legend
Trader Rating: 51 (100%+)
#709
Tech Legend
Joe I did get your message. I will get that stuff gathered up for you.
#711
Hi guys.
I run an XRAY T1FK05 with a MM 7700 on 7.78 (19/87 spur) and it's fast but the same car with a NOSRAM Matrix evolution 2007 and an LRP 4.5 on 8.22
(18/87 spur) it's pretty faster I don't know why.I tried to change the settings on the MM controler but it can't be fast as with the 4.5. I don't know if gearing up would be a solution because already with this gearing the 7700 doesn't accelerate as fast as the LRP.With the Nosram the car seems to accelerate better and having higher top speed and i don't know why this happens.Yesterday i tried the car with the Nosram esc and a REEDY NEO star 4 motor and even this one was faster than the 7700.What do you think about? I have to tell you that i run the same batteries (Lipo 2S) on a large oval area with a straight of 40 meters about,temperatures about 70-72 C in both cases,same transmitter but mamba is not fast as Nosram And im talking about the 4.5 motor not the 3.5. I would appreciate any suggestion or opinion about this.
#712
The MM will use a higher gear ratio then an LRP setup, so try going up a few teeth.
#713
OK but already with the MM the acceleration is not very good.Im affraid that gearing up by 1-2 T it'll be worst.
#714
I have tried my MM geared too low and it fell over itself a bit as compared to when it was geared right.
#715
Gearing up is not a problem (gearing down is ) so i can try on a higher gearing.But your opinion is that the 7700 could be fast as the LRP 4.5 ? If so ,i can try to fix it, otherwise i'll live with this.
#716
Tech Legend
#718
MM 7700 up-geared from 19/87 (FDR 7.78) to 21/87 (FDR 7.04) is still slower on acceleration and top speed from the LPR 4.5 and the REEDY Neo star 4 geared 18/87 (FDR 8.22).What is going wrong here? Any advise pls?
#720
I just got a Mamba Max 6900 ..For my TC4. I tried racing it this past Sunday.. Am using a M11..
At the beginning of the race I mashed on the throttle and the car didnt go...Also during the race it stuttered and then went...I used the default profile with 30 brake and 30 drag brake... Motor timing was set on nomal.... Any thoughts on why this would happen.... Could the speedo be bad...
