Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 06-04-2007, 02:45 PM   #586
HI GUYS
Ok I'm having a problem with my mm7700
I was playing with friends yesterday
For about minutes only
Its a stock tc4 with mm7700 combo
This morning when I wanted to play
It didn't want to run just sitting there a dead duck stuttering.
I figured battery might be drained
Put a freshly new battery its the same thing.
So I figured its my fm radio but its fine what do you think is wrong with it?
Any thing to look for?
I'm begining to think my mm7700 is aint all that
Please guys help
Thanx
HARDRIVE is offline   Reply With Quote
Old 06-04-2007, 03:23 PM   #587
I just called castle creations
And they said to cut the wires from the esc? And solder the wires from the motor to the esc. And I should be fine
What I forgot to ask them is
If I do this will it affect my warranty?
Any body done this to their mm7700?
Did it work for you?
Old 06-04-2007, 03:40 PM   #588
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
yes b4 i sold the motor. i did just that after tiring of dealin w/the stutter. also have done this w/my current 5700 motor as a preventative measure. it does work. good luck and have fun
R
UltegraSTI is offline   Reply With Quote
Old 06-05-2007, 03:20 PM   #589
Default 7700
Hi all
I received my 7700 package 3 weeks ago and so far i have smoked 4 diffs I wanted "O my gosh" and that is what I got, I love it.
I read some where not to use the on/off switch to turn the thing on or off, is this true or false ????
Also can I make my 7700 run more like a 10 turn ???? At least till I get more diffs for my Cyclone TC. I have it at 110-25 with a 2.4 car and rubber tires.
Thank you
Russ
Lazer Guy is offline   Reply With Quote
Old 06-05-2007, 06:07 PM   #590
R
Thanx ultegrasti
So all I have to do is unsolder the wires from my esc.
Cut off the banana connectors from the motor wires and solder that wires directly into my esc?
Did I get it right?
Thanx guys for helping someone like me
Know nothing about electric
Old 06-05-2007, 07:07 PM   #591
Scrad's Avatar
Trader Rating: 15 (100%+)
Yep, just cut'em off and re-solder them. I haven't had any lag or stuttering since I cut mine.
Scrad is offline   Reply With Quote
Old 06-05-2007, 08:49 PM   #592
Mike Haynes's Avatar
Lazer...best bet to slow it down is undergear it, and use a punch conrol...start off around 40% and 4 teeth down.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-06-2007, 04:22 AM   #593
Thanx scrad
Ill work on it tonight
Ill unsolder the wires from esc and solder the motor wires hope it'll work for me
Thanx again
Old 06-06-2007, 06:52 PM   #594
Thank you for the come back, I'll do the punch control at 40% and I'm going to try 7v cut off also. 110-25 is 4 teeth down from where I was, that is as low as I can go on my HPI TC.
Thank you again
Russ
Old 06-06-2007, 09:35 PM   #595
Don't try to use the lipo cutoff as a power limiter, that will cuase you major headaches....good luck!
Old 06-07-2007, 10:47 AM   #596
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Joe Ford...........Thanks for the great customer service.
Brian
ST Racing Concepts (STRC)
Old 06-07-2007, 12:40 PM   #597
Joe Ford's Avatar
Send a message via AIM to Joe Ford
No problem bro.
Joe Ford is offline   Reply With Quote
Old 06-07-2007, 01:43 PM   #598
Hi joe ford
Do you work for castle creations?
If you are could you please help me with some answers
In regards to mm7700?
I have a tc4 with mm7700
I doesn't wanna move luike stuttering
Or can't decide wether to go forward of back
I called castle and told me to cut off wires from esc cut off banana connectors
And solder the motors wires directly in to esc.
What I'm trying to find out is
IF ILL DO THIS WILL IT AFFECT MY WARRANTY.
Also I have a friend who also have a mm7700 the pinion gear break off from the motor. And its only a month old yet
Will it be covered by the warranty
Thanx
Old 06-07-2007, 05:14 PM   #599
Scrad's Avatar
If they are telling you to cut the wires off the speedo, then I would assume that it would still be honored under the warranty. But assuming things will get you in trouble.
Old 06-08-2007, 04:37 AM   #600
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally Posted by HARDRIVE View Post
Hi joe ford
Thanx
Yes, Joe works for Castle. New version of tech and he has not updated his signature.
If he told you to cut off the connectors and direct solder then no it should not void your warranty.
As for the shaft breaking yes that should be under warranty as well.
Call Joe direct at 913-390-6939 Ext 119
Later,
CRASH is offline   Reply With Quote
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
