Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 05-24-2007, 08:15 PM   #556
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
CRASH radio issues will be solved. No more Spektrum and a new toy.
ST Racing Concepts (STRC)
Old 05-25-2007, 03:56 AM   #557
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
yeh bri the mi3 sure does look good.
R
UltegraSTI is offline   Reply With Quote
Old 05-25-2007, 05:50 AM   #558
wyd
Tech Legend
wyd's Avatar
R
It is a really trick car with every adjustment under the sun.
Old 05-25-2007, 09:45 AM   #559
will it void the warranty if i cut off the esc switch? Also, i have 2 fans i want to run off the esc, if i cut the switch, can i wire the fans into the switch wires, if u get what i mean??
cairnsrc.com
REC'd Racing
What I have - Brushless Slash 4600kv, DX2S
What I need - Boss Motorsports 10.5, TRC LCG chassis, Ford F-150 SC body, Proline Protrac & a Brushless XXX-T CR MMP4600kv. Not alot!
Drift Demon is offline   Reply With Quote
Old 05-25-2007, 01:30 PM   #560
Guys I'm having trouble programing my esc on my computer
I did all what drift demon says
When I did that it says control not pluged in?
Is that mean I have to connect my esc to my control first?
HARDRIVE is offline   Reply With Quote
Old 05-25-2007, 01:39 PM   #561
Registered User
UltegraSTI's Avatar
was considerin that mi3 or a tc5 for fall. usin this CC speedo runnin brushed motors since 13.5 (at least novak's offering) cant hack it
R
Old 05-25-2007, 10:49 PM   #562
gndprx's Avatar
Trader Rating: 18 (100%+)
I hate to do this to you guys (Castle), but I'm am being forced to part ways with both of my Mamba Max systems after many tries.
I have a 4600 system and 5700 system and both setups exhibit the same behavior after switching to a banked tri-oval track. If you get spun or stopped in any way, the motor has no clue how to get you moving forward again until you come to a complete stop. If you give it power, it will just stutter until you bring it to a complete stop. This appears to be a major flaw in sensorless brushless systems because if you are rolling backwards, it has no clue how to change the direction of the rotor rotation. It's cost many races and actually caused a few wrecks because I can't get out of the way of oncoming traffic if I get spun...I just have to drift backwards to the bottom of the track and wait for it to stop on it's own.
On dirt this didn't seem be a problem all that often, but as soon as I switched to paved oval it's just bad. And unfortunately every driver who has tried to run the MM on the paved track has experienced this same issue.
I hope you guys can fix this in the future as you do make an exceptionally powerful setup, but without the control factor I just don't see taking over top brushless spot in the market.
Thanks and good luck.
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 05-26-2007, 01:03 AM   #563
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
hi,
my name is matt from sooke b.c. canada
i own the mamba 1/18 compition x pkg
ok so heres the deal
the motor is fried
warrenty covered and replacement or my f*** up and i gotta put up the cash for a new 1?
esc setup -castle link
punch = 100
timing= meadum
no lipo cutoff
brake =50
rev. spd. =75
vehicle- rc18t
batts - 1 6cell 1200, 1 6cell 1100, 1 7cell 1400
radio- kopropo ex10 heilos
i allways left a cooldown period for the motor and esc
never got wet at all
never rapidly cooled
help me
thanks, matt
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 05-26-2007, 06:31 AM   #564
Registered User
UltegraSTI's Avatar
carl, u still usin the bullet connectors? mine would do that til i removed them and hardwired them together. never again in 2mths of racing every wknd
R
Old 05-26-2007, 08:56 AM   #565
gndprx's Avatar
Nope, I replaced one with all deans connectors and one is soldered direct. Both do it in 2 different oval chassis.
I've seen this hit the touring car guys too. The only place I have not had the problem was on off-road.
Carl Fisher
Team Xtreme RC
Old 05-27-2007, 03:08 PM   #566
streetracer745's Avatar
Send a message via AIM to streetracer745
i am currently building a 1/10 electric truggy. im using the tamiya dark impact as a base chassi and am planning on lengthening it, using 7 cells, and using pro-line holeshot tires. i was wondering what the best motor would be for all aroudn good performance. i want either the 6900 or the 7700, but im nto sure if either will do very good with the setup. which motor would yall suggest i use?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 05-27-2007, 08:54 PM   #567
Trader Rating: 32 (100%+)
I'd suggest the 6900 if you're using 7 cells.
gulio is offline   Reply With Quote
Old 05-27-2007, 08:55 PM   #568
would the 5700 be even better? or is the 6900 my best bet for a good combination of speed and acceleration?
Old 05-27-2007, 09:56 PM   #569
anyone
Old 05-28-2007, 07:53 AM   #570
wyd
Tech Legend
wyd's Avatar
I just think a 5700 would be plenty on an offroad car with 7 cells. I can't imagine needing anymore power than what a 5700 will produce for you. To me 6900 and 7700 motors are more for touring cars or cars that have imense traction and will really hookup.
From my offroad racing experiance if your overpowering the track and spinning your tires all the time your not going to run fast lap times.
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
