Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 04-08-2007, 12:36 PM   #391
Default New Mamba Max problem
Hi guys !
I've just bought a combo mamba max 7700. I use it on my Losi XXX-G+ with Nosram quite new 3800 matched packs.
Well, the first two runs were quite amazing. Great acceleration & top speed. Great stuff I though then. But a problem appeared during the following runs. Sometimes, the motor suddenly stops running. When i press the trigger, the motor goes forwards and backwards (but the car doesn't move).
I first thought about a thermal shutdown system but the temp of the ESC and motor seems ok. My radio system seems ok too.
Any idea to solve this ? I read that it may come from the connectors between the ESC and the motor. Is that true ?
Thanks fot the help.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 04-08-2007, 01:44 PM   #392
beast95451's Avatar
I had this same problem in my ZX-5. Called Castle, they told me to ditch the gold connectors, shorten as much as possible & hard wire the ESC to motor wires. Runs like a bat outta hell now!!!!
beast95451 is offline   Reply With Quote
Old 04-08-2007, 01:51 PM   #393
dougmartin's Avatar
Trader Rating: 14 (100%+)
Talking
Well I was bored this morning and was reading on here about the setup for 4 cells so thought I'd setup my Mamba Max 7700 in my CRC3.2r.
It was pretty easy to do. I did what Joe recommended and pulled the + wire from the ESC plug then I soldered a + and - lead to plug into the Batt plug on the reciever.
I double checked everything and hooked up the battery. Servo came to life...turned on the power to the ESC and everything powered up....ESC went threw it's setup.....all works awsome.
Now I can't wait to try it outside...here's a few pics of the install. And one of the club track I race at.
Need to fix up the wiring abit.
Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-12th-scale-mamba-max.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-close-up-mamba-wiring.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-12th-body.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-road-track-pic-1-.jpg
dougmartin is offline   Reply With Quote
Old 04-08-2007, 02:47 PM   #394
Beast 95451, thanks for your quick answer.
I really appreciate. I'm gonna sleep well tonight
Anyway, I don't understand why Castle Crations sells the Mamba max with pre-soldered connectors that aren't reliable.
Cheers.
Old 04-08-2007, 07:36 PM   #395
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
i had the same prob w/mine too. almost exact, the connectors were very very hot when i ran around. not long mind u and in this very cold weather we're havin.
i put a 5700 in my CR and now car runs like clockwork. idk what to do with the 7700. but i am out 90bux with the extra motor.
any1 want a 7700?
R
UltegraSTI is offline   Reply With Quote
Old 04-09-2007, 01:26 AM   #396
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I just put a 7700 in my MF2 and it keeps blowing the spur and slipper apart...it's fast as hell while it's running though.
any1 want a 7700?
R
Turbo Joe is offline   Reply With Quote
Old 04-09-2007, 04:48 PM   #397
CRASH's Avatar
Trader Rating: 26 (100%+)
I solder all of my motors directly to the ESC. I run touring car so this makes it easy. For offroad just solder the wires together and heat shrink. A little bit more trouble but in the long run you will be much happier.
Later,
CRASH is offline   Reply With Quote
Old 04-09-2007, 04:51 PM   #398
CRASH's Avatar
Originally Posted by wyd
I would think the 4600kv is the closest to a 19T but the 4600 is still faster overall.
Our 4600 is more like a 10 single, it is just "FREAKINNNNNNNN NUUUUUTTTTTTSSSSSSSSS!"
Later,
Old 04-09-2007, 04:52 PM   #399
CRASH's Avatar
Just ordered my 6900 motor and hope to try it out next weekend.
Got a 6900 huh? Better hold on to your, well you know! That thing is a parts breaker and makes men weak in the knees!
Later,
Old 04-09-2007, 04:53 PM   #400
CRASH's Avatar
Very nice, very interested to hear some results.
Later,
Old 04-09-2007, 05:14 PM   #401
Registered User
UltegraSTI's Avatar
i will do that, they still get a lil toasty w/the 5700. didnt wanna touch them b/c no matter how many times i read the manual, i didnt wanna cut em. especially when i was havin trouble keepin the 7700 runnin. seriously does any1 want this motor, i have no use for it and cant control it.
R
Old 04-09-2007, 05:26 PM   #402
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Later,
Cool sounds like another parts order to PW at Schumacher.
ST Racing Concepts (STRC)
Old 04-09-2007, 07:06 PM   #403
Registered User
UltegraSTI's Avatar
bob said u guys were runnin 19T down there. how is that workin out.
i'm still on self-imposed exile heh.
R
Old 04-09-2007, 07:29 PM   #404
wyd
Tech Legend
wyd's Avatar
R
It was fun but don't hit the walls as it would rip parts off the cars. It was really fun right after the track was sprayed with WD as they really fast then.
Old 04-09-2007, 08:02 PM   #405
dougmartin's Avatar
Talking
Crash
Do you know of anyone trying the Mamba Max in a 12th scale yet? Any input would be great.
I ran this system in my T2 all indoor season and it was ballistic....and yes I could drive it. Won the club TC mod series.
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
