Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 03-08-2010, 01:46 AM
  #2221
bodymot's Avatar
Originally Posted by Joe Ford
bodymot...this is where mathematical computation comes into play. It's just not possible to punch in any number. The numbers you see are the only ones that will work unfortunately. The motor will not operate with numbers in between what you see. I wish! Was the first thing I asked when alpha testing the ESC...
Shame but still a great Speedo, I was just being greedy .
Thank you for replying so quickly.
Ben
bodymot is offline
Old 03-09-2010, 12:28 AM
  #2222
Born2Run's Avatar
I have two suggestions for the Castle people out there.
1.Power wires on MMP are to short.You should have them a little longer (2cm more should be perfect)
2.For outside US customers you charge a lot on shipping for the "free Castle Link". I paid $16.95USPS First Class Mail International for my MMP 6900 combo on ebay and now you ask me to pay $ 28.00 US shipping just for the castle link adapter and you call it "free"?
Born2Run is offline
Old 03-09-2010, 06:27 PM
  #2223
my mamba max pro will run for about 3 to 4 second at any speed and will shut down but i have to wait about ten minutes until it will turn back on but them does the same thing again??? what is most-likely my problem
vanderham21 is offline
Old 03-12-2010, 03:34 AM
  #2224
bodymot's Avatar
Default castle link
Just wanted to know about when you use castle link for Mamba max pro to computer, you have to make sure the Speedo battery wires +/- do not touch or they get warm (power from computer). Some of us usually run extra capacitor on these wires, could it harm the Speedo or link (just want to make sure).
Ben
bodymot is offline
Old 03-12-2010, 03:55 AM
  #2225
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hi Joe,
You have a PM.
-Wayne Gerber
sg1 is offline
Old 03-13-2010, 04:10 PM
  #2226
vic2367's Avatar
Trader Rating: 14 (94%+)
ok need some help here guys,,am trying too install the castle creations softwarte on my pc running vista ,,im the owner/administrator logged on ,,but i still cant seem too install correctly ,,telling me that " there is a with this windows installer package.a program required for this install to complete could not be run . contact your support personel or package vendor ." anyone know whats wrong ?
vic2367 is offline
Old 03-13-2010, 04:30 PM
  #2227
vic2367's Avatar
wow finally figured it out
vic2367 is offline
Old 03-14-2010, 12:09 AM
  #2228
whoopass's Avatar
guys ran the ESc the other night and all I can say is its FAAAAST. loads of power, cant wait to use it outside, its gonna rip.
however I find that I cannot adjust the drag brake on the handset? well if I do and the car is already powered on its fine, but if I leave the neutral point on the radio at say -10, power the ESC back up. it complains that the MMP cannot find neutral from the radio and does not work. so basically I will have to set the trim to 0, switch on, then set the trim to -10 again.
never had this issue on any other esc.
i suspect the ESC requires to find neutral on the radio before it will run?
cheers
whoopass is offline
Old 03-14-2010, 09:47 AM
  #2229
cheers
It's a built in safety feature. The same happens if you set the trim foreward.
It's there just in case you power up with the wrong model memory or something.
It's best to set the drag brake close on the speedo and just fine tune with the radio. If you use the radio only it will have a big dead band before the throttle kicks in.
Fred_B is offline
Old 03-14-2010, 10:32 AM
  #2230
whoopass's Avatar
cheers fred, thought that was the case, when I adjusted the trim back to 0 or neutral the MMP worked fine. also the switch oon the MMP is huge!
any chance the guys at castle can opt for a smaller switch? I am thinking of cutting it off and solder the wires together as it is huge!
whoopass is offline
Old 03-14-2010, 05:18 PM
  #2231
i just boughta mamba max pro for my tc4 i need help settingit up. i have a final drive ratio of 5.2 im running a 13.5 trinity brushless. i amrunning it on a high traction carpet oval with 43 foot straightawas. ineed help bad on the setup
ralph wallace is offline
Old 03-15-2010, 11:58 AM
  #2232
vic2367's Avatar
anyone know how too connect these motor wires on the mamba monster esc ? have a red ,white and a black wire ...does it matter where the wires are connected to in this esc ?
vic2367 is offline
Old 03-15-2010, 01:22 PM
  #2233
vic2367's Avatar
also my esc wont program into forward,,is it because im using the traxxas stock emaxx radio and has no throttle endpoint ?
vic2367 is offline
Old 03-15-2010, 02:22 PM
  #2234
vic2367's Avatar
found it
vic2367 is offline
Old 03-20-2010, 12:16 PM
  #2235
hi guys,ive got a hyper 9e with a mamba monster esc,and a 2200 motor.running it on a 15t pinion and a reedy 4s 14.8v 5000 40c lipo what would be a good,safe running temp for the esc and motor.
jon9e is offline
