Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 06-03-2009, 12:02 PM
  #2026
Trader Rating: 35 (100%+)
Hi all. Can someone recommend a fan for my MM ESC? Just got the 7700. Installed it in my Rustler. Burned out the stock 12T Titan twice and the stock ESC once. Don't wanna do the same with this. You all know it isn't cheap.
Also, I was thinking about getting a motor guard, but I'm concerned about trapping heat. That silly?
I had read something about putting a hole in the body as well to help release hot air. Anyone got any info on this? Pros, cons.
I'm running it with a 90T 48 P spur with a 19T pinion. Might get a 15T pinion today. I run it for about 15min or more for fun. no racing or anything, but it's very VERY hot around here. So heat is a MAJOR concern.
marooko is offline
Old 06-04-2009, 01:09 PM
  #2027
SavageLV's Avatar
Smile
Hello everyone. I was about to run my savage flux today and I pluged the batteries in and the esc turned on but then it sounded like it poped and then it shut off and it wont turn back on. any ideas?
SavageLV is offline
Old 06-06-2009, 09:38 PM
  #2028
I went to run my sidewinder esc with a 5700 in my xxxt the other day and there was no throttle. I had to to the quick setup again. I had it already setup and raced why did it do this? Have you heard of this? It worked after i did the quick setup.
RChead1 is offline
Old 06-17-2009, 08:46 AM
  #2029
I have a 2200KV Castle motor "one that comes in the combo" and my front bearing has some side to side slop in it. What size is this bearing? I can easily repace it my self I just don't know the size and don't have a set of calipiars handy
alphanut is offline
Old 07-02-2009, 12:31 AM
  #2030
Any recommendations for a MM brushless system for Hot Bodies Cyclone 12x ? Thanks.
3v1rrr is offline
Old 07-03-2009, 09:32 PM
  #2031
Joe Ford's Avatar
Give us a call if you just got it. Definitely should be no side to side movement at all. We'll replace it for you at no cost.
Joe Ford is offline
Old 07-09-2009, 08:22 PM
  #2032
mammoth20's Avatar
Default my monster doesnt like me
i just got my monster esc back from castle after it fried, and once i got it back i reprogramed it, set it to 15.0volt cut off for a 5 cell lipo because thats what im using, and when i turned on my truck to use it, it worked fine until i gave it throtle, and it shut off and then when i turned it back on the three lights went on and it beeped once then the esc turned off instantly and now evry time i try to turn it on it does that same thing every time. i know its not over heated because i never really got to drive it and i checked the cut off to make sure i didnt program it wrong and it was still on 15.0volts so thats right. what could it be?
mammoth20 is offline
Old 07-12-2009, 06:09 PM
  #2033
ABBOTT's Avatar
Talking
Our track is tossing around the idea of a superstock 13.5 4wh class this season. Does a cc4600 have any place in this class? I have never seen a 13.5or 4600 run so i have no idea how bad all the orange and blue babies are going to cry when i try this one!
ABBOTT is offline
Old 07-16-2009, 10:26 AM
  #2034
Default throttle curve.
Can someone give me a basic lesson in throttle curve theory?
Have the MMM/2650 in an 8ight e buggy. got punch control set at 80% but i would still like to settle it down a touch more. I know i can tweak the radio but would just like to know how this function works
Anyone have a good curve they would like to share. I am more interested in smooth power than flat out speed.
tinbndr is offline
Old 07-16-2009, 05:12 PM
  #2035
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I never liked that much throttle punch as I found when racing it made the throttle feel dead until I was almost at full throttle and then the car took off. The throttle just never felt smooth. I would run no more than 20% punch control and then use around 20% negative expo on your radio. Negative expo is just like using the throttle curve on the Castle Link. You can curve the throttle to be very dead down low and at increase the power alot more as you get to full throttle. Just mess around with it some til it feels good to you.
wyd is offline
Old 07-17-2009, 05:28 AM
  #2036
So which way is smoother/ more agressive? do you just plot a point in the center and pull from there?
tinbndr is offline
Old 07-17-2009, 06:17 AM
  #2037
wyd
Tech Legend
wyd's Avatar
If you are looking at the Castle Link you would have the curve line bending down will mellow it out in the middle. If you would run the curve with the bend going upward in the middle it will have more punch in the middle.
Wherever you have the lowest bend in the curve you will have the least amount of punch in that area and wherever you have the highest part of your curve the most punch you will have in that area.
wyd is offline
Old 07-17-2009, 07:58 AM
  #2038
+1
Even more than 50% expo on your radio works well.
Lazer Guy is offline
Old 07-18-2009, 06:53 AM
  #2039
cola's Avatar
Trader Rating: 308 (100%+)
Has anyone run the trinity/Epic Duo motors on the mamba max? It says the motor works with sensored and sensorless speed controls, but I haven't seen anyone run one a mamba.
David
cola is offline
Old 07-20-2009, 03:06 PM
  #2040
neillarson's Avatar
Got my Mamba Monster ESC back from repair today. Had a bad BEC and they added a new engineering change to it that is supossed to stop the fireballs. Didn't work, made it about 5 feet before my Erevo caught fire, thankfully no body as I was testing it.
But now issues, Castle is sending me a new one. Gotta love good service.
neillarson is offline
