Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 02-06-2007, 02:40 PM
  #181
streetracer745's Avatar
how many cells are you running in your XXX4+G? could i see a video or pictures of it at the track and speed runs?
streetracer745 is offline
Old 02-07-2007, 04:33 PM
  #182
superchunkracin's Avatar
I was also noticing the hickups when running stock motors. I've got mine set-up brushed reversing and forward / brake / no reverse. Crash; so I can set it on high power and just use the red and black wires and no jumper to the pack? Also; can you talk to the big wigs about programing the esc with antibrake? I always called it creep. Normally I just crank up the trim but that trows it in to set-up mode. My M11 doesn't have enough trim throw so I have to start in a mod model and then change it to stock. Thanks for the help.
superchunkracin is offline
Old 02-07-2007, 07:03 PM
  #183
CRASH's Avatar
Trader Rating: 26 (100%+)
I am running SMC IB4200s, 6 cell. Don't have any videos or pics right now.
Later,
CRASH is offline
Old 02-07-2007, 07:06 PM
  #184
CRASH's Avatar
They are working on the creep, dead band issue along with the Novak update.
Later,
CRASH is offline
Old 02-07-2007, 07:09 PM
  #185
would my orion 3000s do the job with the 6900 in my buggy? or would i need to upgrade to 4200s? 4200 batteries wouldnt make any mroe power though would it?
Old 02-08-2007, 03:06 AM
  #186
Default mamba esc problem
can i get away with not having the on / off switch on my mamba max esc? the reason im asking is because the red wire is not soldered to the board, i took it to a model shop they tried but they said its not serviceable due to its location, so will i be ok just cutting the black cable off aswell and not using it?
or will i be ok to take it apart via the two screws without breaking it anymore? in order to make the on off switch contacts eaiser to access?
im a bit annoyed because it was like this stright out of the box new never used, im hoping the on off switch is not really required so i do not have to have the hassle of sending it back, its been 2 months already since i started to build my car and iv still not run it yet
Apexs is offline
Old 02-08-2007, 03:30 AM
  #187
CRASH's Avatar
3000s would probably not last with the 6900. The 4200s will make more power and significantly increase run time. This is due to the higher average voltage and the much lower internal resistance.
Later,
CRASH is offline
Old 02-08-2007, 03:33 AM
  #188
CRASH's Avatar
Contact Joe Ford for info on this, either via phone or e-mail.
913-390-6939 Ext. 119 or [email protected]
Later,
CRASH is offline
Old 02-08-2007, 03:45 AM
  #189
thanks crash, email sent
Apexs is offline
Old 02-08-2007, 12:46 PM
  #190
okay. thanks for all your help
Old 02-09-2007, 04:33 AM
  #191
is joeford away from the office?
Apexs is offline
Old 02-09-2007, 05:04 AM
  #192
CRASH's Avatar
I will have hime look for your e-mail this morning. Send another copy to [email protected]
I know he will see it there. He answers 90% of the e-mails.
Later,
CRASH is offline
Old 02-09-2007, 12:53 PM
  #193
does mamba maxx castle link 2.22 work with windows xp pro 64 bit? software installs but when i plug in the mamba max to the usb its a unknown device and it will not install so the castle link software is not detecting it
Apexs is offline
Old 02-09-2007, 03:40 PM
  #194
Regional Moderator
rajS's Avatar
Trader Rating: 35 (100%+)
Originally Posted by rajS
Good Day,
I have been running the MMX 5700 on 3cell lipo 4A/15c on a AETc4 geared (100s/25p).
It performs as it should except, I noticed that if I hit full throttle abruptly, my
ESC lags for a split second, then kicks in shortly after. This does not happen if I go full throttle gradually exercising throttle control.
Any suggestions are welcome.
Thanks,
Raj
Hello Guys,
I did some further testing last night and after trying out a new radio system tx/rx, while using all the previous parameters as listed above, the symptoms are now gone. I can hit the throttle as hard as i can without the strange lag problem.
Could the newer Radio using (HRS) actually cure the odd behaviour.
Oh well,
rajS is offline
Old 02-09-2007, 03:44 PM
  #195
Regional Moderator
rajS's Avatar
Hello Apexs:
After installing the software and as soon as you plug the mamba into the usb link, you will get another screen displaying an unknown device. Simply install the mamba driver by following the popup screen. As soon as it installs this driver, you will detect it within castlelink program.
rajS is offline
