Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 04-06-2009, 10:05 AM   #1906
Originally Posted by Born2Run View Post
Use your soldering iron to take off the bullet connectors and resolder the speedo wires together with wires coming out of the motor.Its very easy.
Surely thats no different to cutting off the bullet?, Also how is your speed now on the 7700kv?, i have heard people say its a 3.5T killer, but to me its barely faster than a 5.5T
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 04-06-2009, 10:16 AM   #1907
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Thanks Ya`All
What type of batteries (NiMH or lipo)? How many cells? Manufacturer of the cells, capacity, and if lipo, what is the C rating? What battery connectors are you using? Which vehicle and gearing? Also, what is the motor temperature after a run? Let me know. A 7700 should not be anywhere even close to a 5.5T....
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 04-06-2009, 11:40 AM   #1908
Hello,
The 7700 is also not even close to a speed passion 4.5 . I am running 2s lipo, its a reedy 5000 35C, using 4mm bullet connectors. it is in a T2`009 with an 8.7 FDR
Thanks Ya`All
Old 04-06-2009, 11:57 AM   #1909
Born2Run's Avatar
Hello,
Thanks Ya`All
Last year I tried the SP 4.5T (series 1) with my mamba max speedo and with an 6.19 FDR was slower than the 7700 on FDR 7.91.Always on 2S lipo.I sold it after a week.I don't know about the SP series 2 but with the Castle 7700 you cannot go wrong.If you' can find the right gearing you'll be surpised with the performance.
Whatever
Born2Run is offline   Reply With Quote
Old 04-06-2009, 01:18 PM   #1910
Hello,
What size track are you running on with such FDR ?
Old 04-06-2009, 01:24 PM   #1911
Joe Ford's Avatar
Something weird going on here. Either the batteries are having a hard time delivering the current the 7700 system wants to draw with your gearing or something is wrong with your motor. If you gear for faster speed (up the pinion, or lower the spur gear tooth count) does it go faster or slower? If slower the batteries are not liking the amp draw.
Joe Ford
Product Specialist
Castle Creations
Old 04-06-2009, 01:49 PM   #1912
Born2Run's Avatar
Hello,
A big one (275m about with a straight of 55m).
Whatever
Old 04-06-2009, 04:17 PM   #1913
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
What are the chances of a Windows Mobile/Pocket PC version of the Castle software? I don't have a laptop, but I always have my phone... It'll stop me having to drive all the way home to adjust my Clodbuster settings...
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 04-07-2009, 12:49 AM   #1914
Hello,
I used these same batteries on the sp4.5/lrp sphere combo and it was fast, i sold the system to buy 2 7700kv mamba max systems, due to all the people saying they are good, i am getting the same results on both systems. The motor is at 198F after 5 minutes on a 8.7FDR. If i gear up it does go faster, but then wont that fry the motor?. The lipo's are warm after a 5 minute race. I thought the 7700kv was suppose to be as faster / faster than a 4.0T ?
Old 04-07-2009, 03:17 AM   #1915
Born2Run's Avatar
Hello,
Weird! 198F after 5 mins on a 8.7 FDR and slower than a SP4.5T? Have you checked your drivetrain,bearing etc?
Whatever
Old 04-07-2009, 07:16 AM   #1916
drivetrain is loose and free.
Old 04-07-2009, 08:08 AM   #1917
Joe Ford's Avatar
Hello,
Timing is at lowest? If not drop it and you'll drop motor temp.
Joe Ford
Product Specialist
Castle Creations
Old 04-07-2009, 08:09 AM   #1918
Joe Ford's Avatar
Not likely unfortunately...we thought of this a long time ago, but there are too many obstacles we found once we looked into it.
Joe Ford
Product Specialist
Castle Creations
Old 04-07-2009, 08:38 AM   #1919
I have tried different timing on the motor, but liked the feel of the std "normal" setting, which i think is 10 degrees.. Is there no set FDR ranges for this motor like you get with other sensored motors?.. i will try an 8.2FDR next time and see how it is..
thanks
Old 04-07-2009, 01:24 PM   #1920
Born2Run's Avatar
MoonTrap if you find the 7700kv not as fast as you expected, there is always the 9000kv.If you can handle all this power.
Whatever
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
