Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 02-23-2009, 09:54 PM   #1861
Send a message via Yahoo to crossover
Thanks drperry. I guess what I was trying to get across was I realize on power there is less weight up there and it should steer easier, but before I converted this truck to brushless it was nitro, same steering servo ( Hitec 5997TG) which is rated at 132 @4.8volts or 181 @ 6 volts for torque and it had plenty of power to turn wheels off power. Maybe this BEC does not put out 6 volts, I have no idea. That would make sense though. I just put a new JRZ9100T in it to see if that makes a difference. So far it seems to. SO maybe the BEC is only around 4.8 volts in the ESC?? This new servo puts out 300oz/in at 4.8 volts.
IT just seems weird that the older Hitec, even going at lower speeds would not turn the wheels all the way over. It just felt like a power issue from the ESC. I will keep testing different set ups to see.
Thanks for the response!!
Losi 8t (OS .28)
Mugen 5T (Tekno Brushless, MMM ESC, 2200KV Neu)
crossover is offline   Reply With Quote
Old 02-23-2009, 10:24 PM   #1862
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
The BEC probably runs at 5 volts, like my Mamba Max. but it depends on the amperage the servo needs to pull... Try an RX pack, with the red wire from the ESC disconnected.
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 02-24-2009, 11:29 AM   #1863
Thanks DrPerry!! I figured it might be a lighter voltage going through there causing the servo to feel weaker. Maybe I will try a separate battery pack for that, hate the extra weight though, these brushless conversions already weigh a TON when you put a monster battery in it.
Losi 8t (OS .28)
Old 02-24-2009, 01:20 PM   #1864
drperry's Avatar
If the RX pack DOES fix the problem, you can always get a CC BEC and make sure it's set to 6 volts... It's good for 10 amps, so it will have no problems at all turning your servo.
Old 03-08-2009, 09:47 AM   #1865
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Thought you guys would enjoy this. My RC8 conversion. Neu-Castle 1517 1800kv motor, 6s 30C lipo, 24/44 gearing...run for 10 min then shut down...don't want to push the motor too hard yet. Not sure if it will handle a full run without going over max...we'll see.
http://www.youtube.com/watch?v=iLwJD9DQ7FU
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 03-09-2009, 06:19 AM   #1866
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
simply ridiculous! tire makers are going to love you guys at castle
R
UltegraSTI is offline   Reply With Quote
Old 03-09-2009, 02:58 PM   #1867
Joe Ford's Avatar
Yep, that's the only downside to putting that much power into a buggy...I got 6 runs on those tires (Proline Badlands). Oh well...the price of fun I guess. Even on the onroad tires don't last long.
Joe Ford
Product Specialist
Castle Creations
Old 03-09-2009, 04:06 PM   #1868
Joe Ford's Avatar
Big news guys!!!
ALL, yes ALL, CM36 motors are now ROAR legal in modified classes!!! That includes not only the re-buildable motors we're working on, but also the ones that you've currently got in your rides!!! TELL EVERYONE YOU KNOW!!!!
Joe Ford
Product Specialist
Castle Creations
Old 03-09-2009, 11:17 PM   #1869
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Joe that thing is crazy. The dog better pray it never get hit at full blast as he don't stand a chance.
ST Racing Concepts (STRC)
Old 03-10-2009, 02:47 AM   #1870
Born2Run's Avatar
Originally Posted by Joe Ford View Post
Big news guys!!!
Great News!!! Joe, could you give us some info about the re-buildable motors you're working on? When do you think you'll release them?
Whatever
Born2Run is offline   Reply With Quote
Old 03-10-2009, 07:44 AM   #1871
Big news guys!!!
That includes not only the re-buildable motors we're working on, TELL EVERYONE YOU KNOW!!!!
WHY re-buildable ????????????? I have 4 years on my 7700 and 3 years on my 4600 and I've never even oiled the bearings, there still fast as hell.
Is there any reason I should take the motors I have now apart ????
To me re-buildable implies that I will have to.
Lazer Guy is offline   Reply With Quote
Old 03-10-2009, 02:47 PM   #1872
Joe, when do you think the new rebuildable motors will be ready? im searching for a new motor, & need it to be rebuildable...
Lazer Guy - i like rebuildable for the fact i can service/maintain the inards, shim the rotor correctly, check/oil/replace bearings, check rotor, etc...
Drift Demon is offline   Reply With Quote
Old 03-10-2009, 08:27 PM   #1873
wyd
Tech Legend
wyd's Avatar
You don't have to do anymore work on them. The tear apart motor is part of the ROAR requirement.
Old 03-11-2009, 12:08 AM   #1874
drperry's Avatar
The occasional bearing replacement will be really nice for those that run in adverse weather conditions...
Otherwise, not gonna notice a lot of difference...
Old 03-11-2009, 08:53 AM   #1875
Joe Ford's Avatar
What Brian said. The only reason we're making them re-buildable was that is one of ROARs requirements. They've grandfathered in our non-re-buildable motors too which totally rocks, and we thank them big time for that...helps out our customers (and r/c'ers in general) a LOT.
Drift Demon...we've got prototypes right now. NO clue when they'll be released. They're not even in the hands of anyone outside Castle right now, and probably won't be for a good while. LOTS of testing needs to be done...
Joe Ford
Product Specialist
Castle Creations
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
