Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 01-26-2009, 09:15 PM
  #1831
drperry's Avatar
Originally Posted by Joe Ford
You only need a USB to micro USB cord...you plug directly into the side of the MM...it will work fine on 32bit...it won't on 64bit. Unfortunately, you can't plug the MM into the real Castle Link to program either.
Brian...I do, but I'm feeling super productive today.
ultegrasti...what do you mean "a piece"?
Is there any plans for 64 bit MM support? I tinker with mine too much to swith between operating systems
drperry is offline
Old 01-30-2009, 04:24 PM
  #1832
Colin8ight-E's Avatar
Hey Joe,
I have the MMM V3 combo 220kv, and I notice my positive and negitive wires are permanently are attached to the ESC but some guys on this website have V3 ESC's that have the Positive and Negitive wires with bullet plugs on them like the motor wire side.
Is this becuase there are old and new ESC's and the factory have changed them slightly?
If so which type is newer then the other?
Cheers
Colin8ight-E is offline
Old 01-30-2009, 09:31 PM
  #1833
LAWDAMERCY>>'s Avatar
Magnets in all of our motors are sintered.
MR ford i got your message about the reason for the delay, thanks for the reply, ill be more patient, product is worth the wait
LAWDAMERCY>> is offline
Old 02-02-2009, 10:13 AM
  #1834
Low_E's Avatar
I have a MambaMax + 5700Kv-motor and a Sidewinder + 5700Kv-motor.
I run them in my Predator and in my Asso B4 and they do a wonderfull job.
With what type of Brushless sensored motor can this 5700-motor be compared in terms of power?
I recently drove a Predator with a 6.5 LRP in it and that car seemed to have less power then my 5700 ... but offcourse a feeling is always very subjective.
Are these motors comparable or should one of the two defenitly have more power?
Low_E is offline
Old 02-02-2009, 01:19 PM
  #1835
Default Snapped 2200KV Motor shaft
Joe -
I am running the Monster Combo (2200kv) in my Mugen MBX5T. 14 tooth tekno long shank pinion, stock spur. I have a Hyperion 4S 5250mah and a 4S 8000mah maxamps pack. I am using the tekno kit for the Mugen conversion with mechanical brakes, no motor brakes, no reverse. Ran it for at the track for the 1st time this last weekend and the shaft snapped right behind the pinion gear. Already called today and they told me to send it back in for warranty, which is great, no big deal.
I question whether I should be using the mechanical brakes, motor brakes or brake drag, is there anything I am doing that is too hard on the motor? The temps were very low on everything while running. Nothing got hot at all. I think I have the punch control set at 10% which needs to go up, and all the other settings set to the lowest (timing, etc..) Still had TONS of snap and power. My track has some tight turns, a big straightaway, and some decent jumps that don't have a ton of run up.
Thanks for any insight.
crossover is offline
Old 02-02-2009, 08:13 PM
  #1836
Joe Ford's Avatar
New E-Savage video by yours truly!
http://www.youtube.com/watch?v=IUmD9BsNk-E
Joe Ford is offline
Old 02-02-2009, 08:35 PM
  #1837
Joe Ford's Avatar
Originally Posted by crossover
Joe -
So you're the one...I heard Thomas repeat what you had told him...heard him say "the 2200 motor's shaft snapped???"...I was just as in shock as he was...that's the first time a Monster Max motor shaft has snapped...definitely include the piece that snapped if you have it. It shouln't be a problem if your brakes are working correctly. Hopefully there's some way for us to check the temper level (hardness) of the shaft.
It's approximately a 9T motor. Do speed testing with the same gearing and battery pack. What battery pack is it by the way? Be speciic...manufacturer, capacity, and, if lipo, the C rating as well. Also, what battery connectors are you using? Let me know.
Joe Ford is offline
Old 02-02-2009, 09:01 PM
  #1838
Default Brakes
Thanks for the note Joe. Any insight on the best brake set up to use? Should I use the mechanical, use the motor to brake the truggy, what's best?
Yeah, Thomas was surprised when I called this morning. He was nice and I appreciate you guys being so helpful. This industry is filled with great customer service companies (hitec, traxxas, amain, castle, nitrohouse, etc...).
Thanks,
Kevin
Old 02-02-2009, 09:11 PM
  #1839
drperry's Avatar
Joe, for checking the temper level, maybe you could look into the machines used for testing the grade of bolts?
drperry is offline
Old 02-04-2009, 09:05 AM
  #1840
Joe Ford's Avatar
Thanks,
Kevin
Kevin...I run mechanical if it's got it, if not the motor is still fine, but it will build heat up on the motor a little faster...as long as you check your motor temps often you'll be fine.
Have to talk with the boss about that one. All the machinery to make the motors is overseas.
Joe Ford is offline
Old 02-09-2009, 10:52 AM
  #1841
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
a sensored unit that could drive touring car motors=piece
kinda hard to even consider runnin a touring car (1/10 size, gee hold ur tongue lol) with brushless and not b'g able to consider castle.
just a request, i'm sure it would drive reigle back into touring cars as well.
R
UltegraSTI is offline
Old 02-09-2009, 10:54 AM
  #1842
Registered User
UltegraSTI's Avatar
Pretty stuck on this setup for my XXXCR 4600. indoor track, hard clay, tight, big jumps, and many of them.
25% Reverse (warmup)
50% Brake
30% D. Brake
60% PC
Normal Timing
0% SP
NC Dead Band
3.2v cutoff.
Brake Curve-Linear
Throttle Curve-Linear but scale pulled down from top. Similar to moving top of shock in a hole or 2. Leaves big spike to WOT at top. Clip this off with -5-10% EPA on Loud 'pedal'.
40% drag brake might just be lil too much. 30-35 might be the ticket.
82/22x2.43=~9.06:1 any thoughts on that ratio. i'm runnin on a 100x55 bullring w/plenty of action and little WOT.
R
Old 02-09-2009, 11:21 AM
  #1843
drperry's Avatar
R
The rules are the only reason you'll need sensored... Once you're rolling, CC systems don't stutter or cog... Unless going dirt slow...
drperry is offline
Old 02-09-2009, 06:04 PM
  #1844
Registered User
UltegraSTI's Avatar
nah, already seen 17.5 and even 13.5s suffer the stutters. forget 21.5s in TA for sure.
R
Old 02-09-2009, 06:10 PM
  #1845
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
R
Hehehe I do like touring but been having alot of fun hanging with everyone at Bumps and Jumps doing the offroad thing.
I will run whatever Castle makes whether sensorless or sensored it don't matter as long as it is a Castle system I will run it. To be honest no one has shown me a better system than my Castle and besides not every company has Joe Ford around!!!!!!!!!!!!!!!
wyd is offline
