Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 12-01-2008, 01:18 PM   #1756
Born2Run's Avatar
Originally Posted by Lazer Guy View Post
Geared at 9.02.... two small clamp on heat sinks on motor and 40mm fan on speedo, Motor temp 200* speedo 185*... .
My MM 7700 on 2s lipo geared at 7,9 with a small fan on the speedo heat sink runs cooler.After 5 mins speedo temp is 120F and motor temp 150 and in a 170 straight im the same fast as the 3.5T if not faster.Something is going wrong with brushless system or your batteries or your drivetrain.
Whatever
Born2Run is offline   Reply With Quote
Old 12-01-2008, 04:26 PM   #1757
Originally Posted by chewiefttc4 View Post
hot motor cool esc cool batts = too small of a pinion
cool motor hot esc hot batts = too big of pinion
warm motor warm esc warm batts = the right size pinion.
I have always gear by temp only, I saw this not to long ago and have found this works very well for me now.
I run from 9.0 up to 10.3 depending on the layout. At 9.6 I don't need a heat sink on my 7700. I'm extremely anal about my car and keep it in tip top like new condition at all times.
I have run 8.0 and my speedo and lipo's were to hot, but yeah it was a rocket ship for sure at the end of a long strait.
I also turn the timing down on hot days, I've never had it all the way up even on cool days.
I would like to know what other people gear there 7700's at on a out door track (350' to 525' R.O.) with many 180* and 90* turns and rubber tires ???????
Lazer Guy is offline   Reply With Quote
Old 12-04-2008, 07:44 PM   #1758
slakr's Avatar
Trader Rating: 31 (100%+)
1/8-E Buggy... how do I make the V3 MMM (1.2) make the motor runin reverse?
The ESC will not allow me to calibrate to the radio (Air MX-3) with my throttle set on reverse
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 12-04-2008, 07:56 PM   #1759
geeunit1014's Avatar
set the throttle reverse on the radio back to normal and re-calibrate. i believe you only need to reverse the throttle on futaba radios. if its not going into reverse, make sure you don't have the reverse lockout profile selected, and you have adequate reverse power set (it wont move if the power is set too low, 30%+ generally works)
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 12-04-2008, 08:30 PM   #1760
slakr's Avatar
I got it thanks to badassrevo... I just swapped over two of the motor wires.
When I calibrated it the first time, everything went just like the manual said... except the throttle and brake were reversed. So I thought no big deal; I will just change it on my radio and redo the calibration. Nope!
I even reset the MMM back to defaults and started over again. With the throttle channel set to reverse on my radio the MMM would not accept the full trottle input during calibration.
Old 12-08-2008, 10:04 AM   #1761
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Originally Posted by tyreguy View Post
I am trying to install the castle link software for my Mamba Monster ESC and when it gets to the end of the install it gives me an error
"There is a problem with the Windows installer package. A Program required for this install could not be run. ....."
Any ideas or help would be great...
I have an HP runnng on Windows Vista. It is fully updated.
I have tried installing from the included CD and from the Castle website.
GeeUnit is right on this one...it's the admin feature on Vista. With Vista you need to install the software a little differently than with other versions of Windows. Click on the following link, and when you get the pop-up window asking whether you'd like to "run" or "save", choose "save". Save the installation file to your desktop. Once the download is complete go to the desktop, right click on the installation file, and choose "run as administrator". The software should install properly after that. Please let me know if you have any other questions or problems. I'm always happy to help.
http://www.castlecreations.com/downl...nstall_312.exe
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 12-09-2008, 11:08 AM   #1762
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Joe, 'PC' says enuff of the "V" word already
any word on that sensored unit. i owe it to you guys to dump that unit into 1 of my tourers.
R
UltegraSTI is offline   Reply With Quote
Old 12-13-2008, 07:11 PM   #1763
stickman310's Avatar
Send a message via MSN to stickman310
Hi,
I have a couple of questions if that's ok
How are Orion 13.5 motors supposed to sound? Mines a Vortex but isn't the latest version, although it still has a sintered rotor. I connected it to my Sidewinder for the first time last night and when revved, it's really loud, almost like the rotor is loose or something, but the guy that sold it to me said that the Orion motors are like that?
I also wanted to know what is the lowest brushless wind the Sidewinder can handle. I want to get a 7.5 LRP Vector X11, but wasn't sure if it could take it.
Thanks.
stickman310 is offline   Reply With Quote
Old 12-14-2008, 03:27 AM   #1764
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by stickman310 View Post
Hi,
Thanks.
Some motors are louder than others. As long as it spins freely it is not a problem.
The Sidewinder isn't really made to run sensored motors so while it could run a 7.5 I wouldn't use one since it is sensored. You should be running motors that are sensorless like the Castle or Tekin Redline motors.
If you want to run those other type motors you need to buy a speedo that is setup to run sensored motors. Any other way and you will get cogging and not get the best performance from your motors.
ST Racing Concepts (STRC)
Old 12-14-2008, 04:07 AM   #1765
The only reason I am running sensored motors is that I can buy them cheap second hand, and I'm only a student so that's all I can afford at the moment. I think I'm the only person in my club running a castle creations esc so therefore noone is selling off any sensorless motors cheap. I haven't actually run it yet but just from revving it, I don't notice any cogging or hesitations.
I'm not racing anyway because I don't have the time so even if it was cogging on initial startup it wouldn't bother me so long as it's fine after it gets going, but would a 7.5 overheat/ruin the esc at all?
Also, I only have one Orion Platinum 4800 lipo so if I did get a 7.5 what would the run-time be like?
Sorry for all the questions
Old 12-14-2008, 06:10 AM   #1766
A friend had a couple of Vortex motors that sounded terrible and it was the motor bearings. It was not that old and the bearings felt good but a new set of bearings made it quite.
plumslow is offline   Reply With Quote
Old 12-14-2008, 06:50 AM   #1767
Yeah,
I contacted the guy that sold it to me and he said that sometimes he just took it apart and cleaned it out and took out the bearings and gave them a good clean aswell and that seemed to make it a little quieter, but it has always performed well and was way louder, but faster than his novak motor, so I have no complaints I guess.
Old 12-14-2008, 12:20 PM   #1768
Dark_gouki's Avatar
Send a message via AIM to Dark_gouki Send a message via Yahoo to Dark_gouki Send a message via Skype™ to Dark_gouki
Joe thank you guys for getting me my other Sidewinder 1:18 esc back in a timely fashion, time to make em cry.
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
All My Whips Are SBD (Silent But Deadly)
Dark_gouki is offline   Reply With Quote
Old 12-15-2008, 01:14 PM   #1769
Joe Ford's Avatar
Exciting news from this weekend!!! Ryan Maifield, Team Associated factory driver, won the JConcepts Clash 2008 event with a Monster Max 2200kv combo on 4s lipo. See this link...about 1/2 way down.
http://www.oople.com/rc/photos/clash2008/day2.html
Joe Ford
Product Specialist
Castle Creations
Old 12-15-2008, 02:54 PM   #1770
wyd
Tech Legend
wyd's Avatar
Hey Joe............Happy Birthday.
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
