Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 10-18-2008, 10:57 PM   #1696
t9dragon's Avatar
Send a message via ICQ to t9dragon Send a message via AIM to t9dragon Send a message via MSN to t9dragon Send a message via Yahoo to t9dragon
Originally Posted by jawa View Post
I can't program my Mamba Max anymore because the Castle Link software does not see it on the PC. I checked everything and tried a different USB cable without success. Anybody has an idea of the Pb?
Have you tried pluging in the battery and then the caslte link and then turn the esc on?
t9dragon is offline   Reply With Quote
Old 10-19-2008, 03:18 PM   #1697
you shouldnt have to turn the esc on, because when you plug it into the comp via usb, its getting its power from the PC to light up the LEDs. You could always try it, but i doubt thats going to help ya out, i could always be wrong too!!!
Drift Demon is offline   Reply With Quote
Old 10-19-2008, 04:15 PM   #1698
t9dragon's Avatar
I have used that method several times on the Mamba 25 and Mamba Max esc's. For some unknown reason the PC wouldn't reconize the ESC's but once I pluged the battery in the software would reconize the ESC's............
Old 10-19-2008, 05:16 PM   #1699
thats really strange, maybe some PCs need esc's power source in order to recognise it, ive never had to do that with my MM though...
Old 10-19-2008, 05:19 PM   #1700
t9dragon's Avatar
I have only done it that way when the computer wouldn't reconize the link or the esc.....................
Old 10-21-2008, 08:47 AM   #1701
rockstar81's Avatar
Anybody have any suggestions for running a 5.5 on a MM? Currently when I run it it runs great and smooth (even from take off) until about 3-4 mins into a run then if you stop it most likely will not start moving again (gets progressively worse) temps aren't 150-160 range. Any help would be appreciated
Dee & Mee Hobbies, Team Academy SBV2, Xray 009, Xray 007, Castle Creations, Spektrum DX3R, Ricky Racer Customz, Tekin, Thunder Power, Duratrax Onyx,
rockstar81 is offline   Reply With Quote
Old 10-21-2008, 05:53 PM   #1702
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
To me that sounds all like the battery cannot put out the power to the motor and speedo after it runs for for that 3 or 4 minutes. I don't think the battery is strong enough.
I would try a good lipo pack if you have a buddy or someone that has a good highend matched NIMH pack. I would try this first and see what happens for you.
ST Racing Concepts (STRC)
Old 10-21-2008, 06:43 PM   #1703
t9dragon's Avatar
What battery are you using? brand, mah, lipo, nimh, nicad
Old 10-22-2008, 03:22 AM   #1704
2 things.
1 - battery plug, when it starts doing it, check to see if the plug is warm or not. exact same thing happened to me, i was using venom 'deans style' plugs & found them to be the problem, they would heat up, resistance.
2 - check your on/off switch, i cut mine off because it was not making proper contact, meaning id have it in the on position & the slightest 'tap' would trigger it to turn off, cutting the switch off & soldering the wires together certainly fixed that problem...
Old 10-22-2008, 06:59 AM   #1705
rockstar81's Avatar
I have tried most of my batteries, Reedy 5000 lipo, Losi 5000 lipo, Venom 5000 lipo, and others. I am using real deans, I have ran a Tekin 2.5r with no issues. Wires get a little warm but not particularly the connector. I also tried reflowing all my solder joints. Any other ideas or suggestions? Thanks for your input guys.
Old 10-22-2008, 09:40 AM   #1706
I have a suggestion for you When your car stops look at the speedo, are there any LED's on or flashing ??? If the LED's are flashing it's telling you whats wrong. I don't have the flashing code with me now but you can look it up on the Castle site.
Lazer Guy is offline   Reply With Quote
Old 10-22-2008, 09:52 AM   #1707
t9dragon's Avatar
Do you have the LVC set for the lipos you are using?
Old 10-22-2008, 03:14 PM   #1708
rockstar81's Avatar
I have the cutoff set to auto lipo and it always seems to detect them properly.
Old 10-22-2008, 03:33 PM   #1709
1 flash = Start failure
2 flash's= low voltage cut off
3 flash's =Over current
4 flash's =prop strike or some thing locked up
5 flash's =poor radio signal
I've found this helpful if my car stops.
Old 10-24-2008, 08:51 PM   #1710
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
just got my mamba max back from its 'winter cleaning' and lemme just say that the 'N' brand woulda charged me 75bux for the service that this setup got. i even tried to supply them with a new rx connector which is what i sent it in for, but they returned it to me and told me to keep it lol.
thx again, 1 more reason that my m18 wont use anythin else again.
R
UltegraSTI is offline   Reply With Quote
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
