Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 09-14-2008, 07:14 PM
  #1651
Tony_B's Avatar
Trader Rating: 17 (100%+)
I agree. Too many rules, not enough fun! Lets race!!
Tony_B is offline
Old 09-16-2008, 09:00 AM
  #1652
Default Mamba Max
I was wondering if I can use a Mamba Max 5700/7700 with 4 cells? I used it with 6 cells in my RC10L2 but they changed our class rules to 4 cells for this year.
Thanks!
JoeRocket is offline
Old 09-16-2008, 07:49 PM
  #1653
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Tony_B
being that the MM is sensorless, is it allowed in ROAR races or is it up to the consensus at club races? I just to make sure that I get a esc that I will be able to use for many classes. It p*sses me off that I have 2 perfectly fine Novak GT7's, a LRP quantum and a GM esc in my "inventory" which now that I coming back into racing after 2 years.... are somewhat obsolete!
esc is legal, motors are not.
the 17.5 motors is the stock equiv., however as wyd said you wil lhave trouble with start up (off the line)
geeunit1014 is offline
Old 09-18-2008, 05:27 AM
  #1654
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Thanks Joe F. !!!!!!!!!!!!!
wyd is offline
Old 09-28-2008, 05:54 AM
  #1655
Trader Rating: 82 (100%+)
sorry if this was asked before but is 150 to 160 deg F a safe temp range for my mamba max? i ran several 7 minute offroad sessions with my durga. my orion vortex 4.5 was also in the 150-160 deg F range. should i use a cooling fan on both the esc & motor? the buggy ran fine, but i really dont know what temp range i should be looking at. thanks in advance for any info
marvi is offline
Old 09-28-2008, 06:18 AM
  #1656
wyd
Tech Legend
wyd's Avatar
Anything less than 200 degrees is ok. If you have room for a fan on the speedo I would use one as it never helps to run cooler if you can.
wyd is offline
Old 09-28-2008, 08:23 AM
  #1657
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
big up to gee for doin the micro mod to my sidewinder (25) speedo. much smaller footprint that makes life on an Exotek R3 possible.
R
PS-Joe, mamba max is en route with a new rx connector to be put on the unit. hoping to get the bullets replaced since we all removed them to deal with the 7700. thx.
UltegraSTI is offline
Old 09-28-2008, 05:42 PM
  #1658
dido41's Avatar
what other brushless motors work on the mamba max esc? the run the 13.5 and the 17.5 motors at my club. i just want to be able to change out to run them classes.
dido41 is offline
Old 09-28-2008, 05:49 PM
  #1659
bigb11's Avatar
Trader Rating: 59 (100%+)
can I use a trinity brushless motor with the sidewider esc?
bigb11 is offline
Old 09-28-2008, 06:48 PM
  #1660
thanks ill check our lhs for any fan that will fit the esc, i may be able to squeeze one in
marvi is offline
Old 09-28-2008, 07:23 PM
  #1661
You will experince trouble off the line with sensored motors. Not really reccomended until the new ESC comes out, unless you have a freind to roll you at the start, and then you don't do anything during the run that will make you stop
Pretty much any motors availabe (not sure abt the new novak ones) will work with the 1/18th ESC's.
Old 09-29-2008, 05:43 AM
  #1662
wyd
Tech Legend
wyd's Avatar
The Tekin Sensorless motors will work with the Mamba but not the Tekin Redline series as they are for sensored type speedos.
wyd is offline
Old 10-01-2008, 05:35 PM
  #1663
Tony_B's Avatar
Default Can't reach the USB!
Anyone come up with a way to fit the Mamba Max in a B4 with enough room so that you can still get a USB cord to plug in?
Tony_B is offline
Old 10-01-2008, 06:08 PM
  #1664
t9dragon's Avatar
Cut a hole in the ridge on the side of the chassis...................
t9dragon is offline
Old 10-01-2008, 06:10 PM
  #1665
Tony_B's Avatar
thats what I was afraid of....... any loss of rigidity or a weak point. Have you been runnin like that?
Tony_B is offline
