Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree3Likes
Old 01-30-2007, 05:12 AM   #151
Glowster21's Avatar
Trader Rating: 116 (100%+)
How's that software update coming for the sensored brushless motors?
Glowster21 is offline   Reply With Quote
Old 01-30-2007, 05:51 AM   #152
Racer4Life's Avatar
Trader Rating: 18 (100%+)
Yes,
This is the only thing holding me back from making the purchase!
Racer4Life is offline   Reply With Quote
Old 01-30-2007, 06:48 AM   #153
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally Posted by streetracer745
all i can afford right now is the system. so i will only be able to run 6 nimh...
Try our new 6900 system. It is awesome!
Later,
CRASH is offline   Reply With Quote
Old 01-30-2007, 06:52 AM   #154
CRASH's Avatar
Update is coming along. The Mamba seems to be running them extremely well. The engineers are still doing some testing.
Later,
Old 01-30-2007, 01:46 PM   #155
streetracer745's Avatar
Send a message via AIM to streetracer745
will it make as much power as the 7700 though?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-30-2007, 02:15 PM   #156
CRASH's Avatar
No not as much power, but more controllable.
Later,
Old 01-31-2007, 10:43 PM   #157
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post battery
hope this is the right thread to ask but I bought a new AE RC18R and want to know the best way to charge the stock 6cell NiMh 1100mAh pack useing a GFX cutoff,peak detect charge amps and if I want to cycle it the cutoff voltage and dis charge amps ..right now I charge @ 1amp peak det .02 any help will do thanks ..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-01-2007, 06:21 PM   #158
Send a message via MSN to sampaio Send a message via Yahoo to sampaio
Hi all,
after more than one moth my System: Mamba Max + 5700 is here. I installed into my car, performed the radio setup... everthing ok
So, I turn off the ESC, remove the batteries and put the USB cable, the software, version 2.22, detect the ESC and show the configuration..... I just try to save the configuration and the follow error message are showed:
Error Communicating with device Unable to write packet to controller Try unplugging and reconnecting USB Device.
The software lost the connection with the ESC and few moments connects and work again, I can read the data from ESC, the lights gren and reed alternate turn on/off.
I try to remove/insert the cable n times but woithout any progress.... so now, I remove the cable and put the batteries and turn on the ESC. The red and green lights a solid on, without any response......
So, any ideas?
Thanks in adavance
Sampaio
sampaio is offline   Reply With Quote
Old 02-02-2007, 06:06 AM   #159
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Sampaio...if you can get the ESC to connect, go to the software tab, and click "update firmware". That should solve it. If you cannot get it to link back up let me know and I will get a new one out to you.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 02-03-2007, 08:53 AM   #160
Regional Moderator
rajS's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to rajS
Talking Would Large Capacitors improve performance
Good Day,
I have been running the MMX 5700 on 3cell lipo 4A/15c on a AETc4 geared (100s/25p).
It performs as it should except, I noticed that if I hit full throttle abruptly, my
ESC lags for a split second, then kicks in shortly after. This does not happen if I go full throttle gradually exercising throttle control.
My question is this: Will adding a large capacitor (30v6000uf??) parallel to the ESC's battery terminals remove this behaviour.
(I did this to my mamba25 using 16v1000uf and this improved acceleration)
Any suggestions are welcome.
Thanks,
Raj
...Living the RC Lifestyle since '85... :)
Team Associated * A123 * Spektrum AIR * Castle Creations * Futaba 4PK * * Tamiya 103RM * BAJA5ss * Losi 8B/TE 2.0 * Lots o' Planes
rajS is offline   Reply With Quote
Old 02-03-2007, 09:55 PM   #161
would the mamba 7700 motor have enough torque in a 4wd buggy? i know lots of people run the 5700 in ST's, but dont know of many that use them in 4wd buggies. people have run novak 4.5s before.... what is the 7700 in equivalence to a novak or reedy motor? 5.5? would it be enough torque to lift the wheels off the ground? does anyone have a video of a 7700 in a 4wd?
Old 02-03-2007, 10:35 PM   #162
Mike Haynes's Avatar
Raj, it may have something to do with the 15c rated pack not supplying enough power (burst) try gearing ti down a couple teeth.
Street, the mamba's will push as much as the battery can supply power for, in my touring car the belts will skip before the mamba misses a beet.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-03-2007, 11:02 PM   #163
this is a buggy though. bigger tires, different gearing. will it do ok with that? i mean yank the front up fast?
Old 02-04-2007, 08:26 AM   #164
CRASH's Avatar
Which 4wd bugggy are you running? I have a Mamba 6900 system in my XXX4-G+ and is extremely fast! More torque then I know what to do with coming out of the corners.
That is running it with IB4200s.
Later,
Old 02-04-2007, 08:28 AM   #165
CRASH's Avatar
Originally Posted by rajS
Good Day,
Thanks,
Raj
I agree with rcracingkid, this sounds like the motor is not getting enough volatge an initial full throttle to get it going as quickly as you would like. Try gearing down like suggested. Also what are your settings at on your esc?
Later,
Castle Creations Appreciation Thread TeckLancer Electric On-Road 2 08-12-2008 03:16 AM
FS: Castle Creations Sidewinder with Mamba 5700 Brushless setup with Castle Link salteen R/C Items: For Sale/Trade 0 06-24-2008 06:51 AM
castle creations Mamba BL ESC and Trinity cobalt "B" BL motor , castle link USB vintagetamiya R/C Items: For Sale/Trade 3 01-14-2008 05:25 PM
Castle Creations Mamba Max paul73rc Australia Wanted to Buy 6 01-04-2008 03:41 PM
FS: Castle Creations Mamba Max ESC Mustangz R/C Items: For Sale/Trade 4 12-16-2007 07:52 AM
