Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-16-2007, 05:17 AM   #91
ChrisP's Avatar
Have you also checked to make sure that you are running the current firmware in your transceiver?
ChrisP is offline   Reply With Quote
Old 11-19-2007, 08:41 PM   #92
PeteB's Avatar
Hi Chris,
Yes, the current firmware is installed on both Tx and Rx. i reinstalled them anyway. still reads 14.xx volts in the batt...
Pete
PeteB is offline   Reply With Quote
Old 11-19-2007, 09:27 PM   #93
ChrisP's Avatar
The easiest method to get this answered will be to contact Nomadio support directly at [email protected] or calling support during business hours...
Contact info can be found here: http://www.nomadio.net/contact.php
Old 12-24-2007, 04:26 PM   #94
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've run with a Nomadio Sensor almost since they were first out. Love it in my Mugen and Kyosho gas cars as well as 1/10 scale pan cars. However, I've not had good luck with it in my 1/12 scale car. Nomadio sent me a capacitor to put into the transceiver, which helped. But I was still not happy with the operation and size.
What has been the results of using the Sensor with a Spectum Pro Micro receiver?
I'm heading off to carpet regionals and then nationals and really would like to get off crystals.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-27-2007, 08:06 PM   #95
Kregger's Avatar
I run my Sensor with the Spectrum recievers. (standard and Pro micro) in both my 1/10 and 1/12 scale cars. Haven't had any issues. You do have to run it with a capacitor though.
Kregger is offline   Reply With Quote
Old 12-27-2007, 09:25 PM   #96
Grenade10's Avatar
What do you do to bind the receiver to the radio?
The capacitor would be the spectrum one correct?
Thanks for the help!
Old 12-27-2007, 10:00 PM   #97
ChrisP's Avatar
To bind the receiver, make sure the radio is in the DSSS Beta mode, and set the receiver to bind, as per the Spek instructions...
In the Manage Models directory on your transmitter, you can then select 'rebind' and it will recognize that the Spek receiver is looking to bind and it will couple with your transmitter....done!
note: the steering the throttle positions on the transmitter when rebind is selected will be saved by the spek receiver as 'failsafe' positions and that changing the failsafe settings in the transmitter will not effect the failsafe settings in the spek receiver.
Old 01-01-2008, 03:40 PM   #98
Kregger's Avatar
yep it would be the spectrum one. Although I suppose you could use anybodys. I bind it the way ChirsP says.
Old 01-01-2008, 05:01 PM   #99
Grenade10's Avatar
I have the new firmware, but how to you get to the DSSS mode?
Old 01-02-2008, 03:52 PM   #100
Kregger's Avatar
you have to hook up the sensor to your computer. In the nomadio software select preferences and then application in the drop-down menu. From there you should be able to switch modes.
Old 01-02-2008, 04:40 PM   #101
Grenade10's Avatar
Thanks,
I'll try this tonight!
Nomadio losi guy Radio and Electronics 124 08-20-2010 07:51 AM
w.t.t. nomadio sensor for a nomadio react xtreameracer R/C Items: For Sale/Trade 4 12-07-2007 07:36 PM
Nomadio NitroOB4You R/C Items: For Sale/Trade 9 05-01-2007 08:16 PM
Nomadio J.Wright R/C Items: For Sale/Trade 2 08-01-2006 10:37 AM
