BANZAI Motors
#4681
HI SCOTT GOING TO S.D SEE YOU NEXT WEEK
#4686
Good morning puddle. All of our Checkpoint Mods come with the composite end bell. The reason for this is to keep the cost down for us OEM companies and they have been performing flawlessly.
#4687
Some other highlights of Banzai motors. They are one of the last if not THE last companies to Weld the tabs on there motors. This means you will not loose a wind if the motor gets too hot like some other motors builders that use a cheaper easier solder method. The motors are also HAND wound. No machines, just a hand crank. This gives Banzai' master winders all the control they need to make sure your motor is wound right. It might be a little harder and take a little more time but that is detail, time and effort that goes into each and EVERY Banzai mod motor. Lastly every step in winding the mod motor is done in house. They hand dip the arm in epoxy and bake the epoxy in place, and then balance the arm on a custom balancer. The comm is then trued on a lathe and assembled and test run. It is this attention to details that make Banzai motors separate themselves from the rest. This is not just another company that just buys wound arms and assembles motors they build the motors from the ground up!
#4688
Coming back home from a 200 mile ride on the German Autobahn - average speed ~100-120 mph - i can tell, that i won the 2nd qualifier race in our region in 4 wd stock. Unfortunately not with BANZAI power - motors are handout - but Slingshot cells give me an unfair advantage over the competion
The grass track was wet in the morning , but dried out in early afternoon, mains are complete dry. Had to do a lot of work with setup, because the track gets bumpier than last time.
Tire choice was PL Holeshot M3 front and Schumacher minipin yellow rear - must sound really weird to you.
Next race is the Nat's warmup in 4 weeks.
Regards to all from the other side of the pond
Ebi
Team Durango
Ebi
Team Durango
#4691
Suspended
Any body could wind a mod motor , its the solder,epoxy and oven time that makes a armature that doesnt fail..
#4692
You ready for a Spurs vs Cavs showdown Judi!! This should be a great finals! Ill try not to laugh too hard when Duncan shuts down LeBron. lol.
Im ready for the Nats! While my performance the past few weeks hasnt been up to my standards, im getting the k-car RB5 figured out. Hopfully luck will follow me to New Mexico and I can put in some blazing runs. If not, im still going to have a great time on vacation! lol.
#4695
The welds or the as you say" cheaper method" soldering is ONLY as good as the person doing the work..Most if not all motor failers happend when the epoxy fails..Its the epoxies job to hold the wire in place when it goes up and over the tab and down into the next segment ..Hands down the Peak/Orion motor dept. has the dipping down, not very many failers do to epoxy reaching its heat limit and throws out...Blown wind..
Scott
