Ask Team Tekin
#1291
Martin Paradis
#1292
#1293
Technically fast is good signal processing for sure, but my point is that most people drive better when the servo is not too fast and twitchy. All of the input and output is really the radio and receiver. Once receiver sends the signal to us there is no output from servo going back and we just do what the signal says.. Some drivers even turn down the radio signal rate to the slowest setting of 20ms to make it less touchy to wheel movements. The signal rate from the radios when on the fast settings is silly fast and honestly many products ignore most of them anyway. We do react to every radio signal. So it is really more of a feel issue and tuning.
#1294
We have a new ultra strong rotor coming out for our SpecR motors that will increase the torque. Overall the SpecR motors are a higher kv design for flowing tracks and need to be geared a little lower than most other motors. For a short high grip track with tight layout I hate to admit it may not be the best choice. We will see with the new rotors.
#1295
Martin Paradis
#1297
Yes. Any hotwire we have ever made works with any esc we have ever made after the G11 units. You will need the adaptor that comes with the Hotwire 3.0 to connect to the RX plug of the FXR. HW3 has the smaller plug for the program port on all the newer esc's.
#1299
Speaking of hotwire, does version 1 of the hotwire work with Android 12?
#1300
Howdy, I recently got an RX8 GEN3 and installed it in an EB48 2.0 with a Futaba 4PM radio system. The ESC and motor are lagging or cogging. It won't accelerate from a stop. It says there for a second or two, then accelerates hard or it doesn't move at all. I reset my transmitter and did a factory reset on the ESC, then recalibrated the ESC. It still does the same thing. Any tips on how to get it to work? Thanks in advance.
#1301
I replaced the sensor cable and I think that fixed it. Stay tuned
#1302
Hello, I damaged my T8 Gen1 4030 rotor (1400kv, 6S setup) a few years ago just before stopping the hobby. I'd like to repair it now that I'm back. Is this the correct replacement part ? TT2371. Should I check for something special inside the motor? Everything seems fine but I want to make sure the replacement rotor won't blow up. Is there a certain longitudinal play to look for when rebuilding the motor? Do you have the size of the spacers which are needed eventually? Many thanks.
P.S: This specific motor did 3x endurance races (10 hours, 10h, 12h) plus other races and trainings so I can't blame it. Tekin products have been the most reliable for me so far.
