Like Tree77Likes
Ask Team Tekin
Old 09-19-2020, 03:05 PM
  #1231
MaxRain's Avatar
MaxRain is offline
Old 09-28-2020, 12:18 PM
  #1232
KE4PJO's Avatar
What's the difference between the TT2764 and the TT2769 6.5 motors?
KE4PJO is offline
Old 10-03-2020, 12:32 PM
  #1233
MaxRain's Avatar
Does anyone use the T-120?
I am waiting for my pkg to arrive and I am curious to know if anyone currently use the same and what settings is recommended for TC?
I currently use a Sanwa MT-s with 482's
MaxRain is offline
Old 10-03-2020, 08:55 PM
  #1234
I run a T-120 in a T4 '20 right now. I previously used this servo in an XB2C both with a Futaba 4PX. My only setup change was to turn the servo speed down in the radio to about 85% and have settled on about 90% in the T4 any faster and I'll oversteer the car into trouble. I had a sponsored driver suggest to change the speed limit to .08 which would also slow it down and what was suggested to him along with running the BEC at 7.4 instead of 6. The set center function of the servo was my favorite as no more messing with servo horns and splines.
sweems is offline
Old 10-21-2020, 09:19 AM
  #1235
KE4PJO's Avatar
I prefer the T-180 for TC, much greater torque, holds the hard-fast corners and the speed is just right....for me.
KE4PJO is offline
Old 10-21-2020, 09:20 AM
  #1236
KE4PJO's Avatar
Anybody?
KE4PJO is offline
Old 10-22-2020, 03:35 AM
  #1237
HarryLeach's Avatar
Anybody?
The TT2764 uses the spec-r Blue rotor (TT2776, Same as the spec wind motors).
The TT2769 comes with the Torque Green rotor (TT2777).
As far as differences in gauss ratings, I couldn't tell you, they're both listed as 12.5mm rotors. Though the TT2764 is listed as a 1/12 motor.
KE4PJO likes this.
HarryLeach is offline
Old 10-28-2020, 03:19 PM
  #1238
Hey. I just started getting back to RC after 8 years of break. I went to test my tlr 22 buggy with a Tekin RS and then I tried to adjust the slipper.. gave it full throttle for less then 2 seconds and the esc gave some smoke and now the esc is giving 1-2 and 6-7 fault code.. I desoldered the wires and tried to open the esc, well its easy to open but the pcb:s seem to be sandwiched together somehow.. It looks like they're pins but they dont come apart with any reasonable force.. Any ideas on how to get them apart to maybe find the faulty component that is causing the short? I live in finland and the Esc is already rather old so I guess sending it to Tekin service is not an option.. I'm quite confident that I can replace the components if I can just find the broken ones.
Jukis is offline
Old 12-14-2020, 06:38 PM
  #1239
MaxRain's Avatar
Had lots of fun running this past weekend with a T-120, RS Gen2 and 17.5 G4 in my car...
enjoy
MaxRain is offline
Old 12-24-2020, 03:53 PM
  #1240
Bubblehead21's Avatar
Default Tekin Spec-r motor timing
Spec-r 13.5t and 17.5t analyzing motor timing question.
I am using a GForce motor Analyzer but don't see any higher rpm or current draw with timing adjustment, I have run 0 up to 60 degrees.
Any ideas?
Thanks for any help!
Bubblehead21 is offline
Old 12-27-2020, 10:14 PM
  #1241
Default tekin rs pro BE
I have a tekin rs pro black and tekin eliminator 4.5t.i make a short burn out and make 1 short pass i touch the capasitor and i to hot.i check wire and its in good temp check data and the esc temp its im 120 the capasitor hiTemp its normal or no
Kervin1 is offline
Old 12-28-2020, 12:45 AM
  #1242
LOW ET's Avatar
Trader Rating: 109 (100%+)
these may be of some help for your drag car. i know there is some talk in one of them about the hot capacitor.
LOW ET is offline
Old 03-10-2021, 12:12 PM
  #1243
trilerian's Avatar
Trader Rating: 51 (100%+)
Can you buy cases for the rs pro be? Every rs pro esc I have had over the years always breaks in the same spot. Where the screws go into the top of the case.
EDIT: Never mind, I found the cases on the website. Wish there was a search feature...
trilerian is offline
Old 04-03-2021, 07:22 PM
  #1244
Hello
I just purchased a gen 4 17.5 motor
I run 2 wheel drive stock buggy
Any timing recommendations?.......thanks
bud3738 is offline
Old 04-04-2021, 06:08 AM
  #1245
Originally Posted by bud3738
Hello
Start with 42-44* and proper gearing for your track. check motor temp after 2-3 min. try to keep temps 130-145; less than 150*. Adjust timing from there.
freebird is offline
