Like Tree21Likes
Ask Team Tekin
Old 02-01-2019, 10:21 AM
  #1111
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
Originally Posted by trilerian View Post
I posted this in the RS Pro thread, but maybe I will get an answer here.
Hello, I am using the 1st gen hotwire with my rspro black esc. The hotwire works fine for programming the esc, and for viewing the data logs on my phone, which is great. But, is there an option to download the data logs to my phone? I know there is an option to download the logs when using my pc, but I don't take my laptop to the track, already too much to carry. And with the memory in the esc being so small, I get very limited data to analyze. Also, there seems to be 8 runs stored on my esc that I can't delete. I erase the logs, but those still remain.
I am not aware of a way to download the logs to a phone. Did you wipe the logs from the esc or the app?
Wildcat1971 is offline
Old 02-11-2019, 11:49 PM
  #1112
Brutus279's Avatar
Originally Posted by iTz Nicholas72 View Post
Saw on the new R1 ESC you can change from A-B-C to C-B-A. Is this something that could be added in a future firmware update? Would make wiring up my A800X MMCX-A a little bit neater...
Interesting idea. Do you have to switch the wire layout in the program or if the ESC learn it? I guess I could be learned by the esc during the calibration process the same way a flight board learn the motor rotation direction by turning them manually during a drone configuration. It would make the whole process quite simple for the end user.
Brutus279 is offline
Old 02-12-2019, 05:44 AM
  #1113
KE4PJO's Avatar
I have a question for all the Tekin drivers, both on-road and off-road. Why are there not more setups posted on the Tekin website??
KE4PJO is offline
Old 02-14-2019, 02:38 PM
  #1114
Panther6834's Avatar
Team Tekin...I currently have a Rustler 4x4 VXL, and will be installing a recently-purchased RX8 Gene ESC, and Pro4 Gen3 3300Kv motor. Additionally, I have the Hotwire 3.0. The Rusty won't be used for insane jumps, craving into things, etc...it will be used primarily on a track (indoors), with occasional outdoor use...maybe even some same. That being said, I've got two "project" vehicles on the front-burner, plus I just ordered a buggy kit, all of which will need electronics.
For what should be obvious reasons, I'd prefer to stick with a single brand. I know plenty of people use Castle & Hobbywing (especially racers, of which these three other vehicles will be used for), but I'm still considering Tekin first. The question (actually, "questions", as the same question will apply to each of the three vehicles) is, which ESC, & which motor, goes best with each vehicle. As for what the vehicles are, the first two are "complicated", but the third is "definite".
Regarding the first two, I will be using Traxxas 4x4 LCG chassis - one from a Slash 4x4, the other from a Rustler 4x4. One will be converted into a 1/8 4x4 buggy, while the other will be a short-course truck, both intended for racing (primarily indoor dirt/clay track). My preference is to try using the shorter Rustler chassis for the buggy, to which the Slash chassis would remain a SC truck. However, if my buggy body won't fit the shorter Rustler chassis, them the buggy will be based on the Slash chassis, and the SC truck (albeit, a shortened truck) will be based on the Rustler chassis. It's 6 of one, and a 1/2 dozen of the other, as to which way things will work out. As for the third vehicle, that will be the just-released TLR 8ight-XE buggy.
So, in regards to ESCs, as well as motors, for each vehicle... What are your best-recommended combos?
Panther6834 is offline
Old 02-21-2019, 02:36 PM
  #1115
Team Tekin
Randy_Pike's Avatar
We've been updating the site over the past 30 days or so. If you need or would like a specific setup, let me know and I will post them.
Randy_Pike is offline
Old 02-21-2019, 02:37 PM
  #1116
Team Tekin
Randy_Pike's Avatar
Anything on a 4wd SC platform should be an Rx8 or Rx4, Pro4 or Pro4 HD series of motors.
Old 02-21-2019, 04:09 PM
  #1117
Unfortunately, that didn't answer my question, as I was asking about not only three different vehicles, but three different types of vehicles - a 1/8 buggy (TLR 8ight-XE), a 1/10 SC truck chassis (LCG Slash 4x4) that's been converted into a 1/8 buggy, and a 1/10 stadium truck chassis (LCG Rustler 4x4) that's been converted into a SC truck. While the first two are similar, they're not the same, as one has a heavier metal chassis, and the other has a much lighter plastic chassis.
Old 02-21-2019, 06:07 PM
  #1118
I think Randy did answer your question. He knows his rc car line.
freebird is offline
Old 02-21-2019, 07:39 PM
  #1119
I'm sure he knows his "RC car line", but, at the same time, just using the ESCs as examples, a person wouldn't put an RX8 & RX4 into the same vehicles, any more than they'd put a Pro4 & Pro4 HD into the same vehicle. Except ESC, and each motor, has specific vehicle types they ffi best into. Would you put a Ford 351 V8 engine in a Ford Pinto? Of course not. Even though it could fit, that engine would be completely wrong for that car.
No worries, though, as I'm now looking into other options (although, NOT Castle).
Old 02-23-2019, 03:05 AM
  #1120
KE4PJO's Avatar
Sure, I've known several guy's that have done that...
KE4PJO is offline
Old 02-23-2019, 07:48 AM
  #1121
Trader Rating: 60 (100%+)
Spec R 17.5 in a b6.1. Gearing and timing recommendations?
Antimullet is offline
Old 02-23-2019, 07:37 PM
  #1122
KE4PJO's Avatar
OK..How about some hotwire settings for TC. 17.5 or 13.5 blinky? Or even some settings for the guys that run the CanAm series motors, I know they're out there.
astgerma52sp likes this.
KE4PJO is offline
Old 02-24-2019, 05:52 AM
  #1123
Trader Rating: 14 (100%+)
F1 25.5 on high and low grip surfaces too.
astgerma52sp is offline
Old 02-24-2019, 09:03 AM
  #1124
Tekin Spec R 17.5 carpet buggy B6.1. Any recommendations for gearing and timing starting points?
Old 02-24-2019, 06:13 PM
  #1125
ThinkFast8's Avatar
Trader Rating: 1 (67%+)
Team Tekin, Left 1/8 nitro some years ago but my grandchildren want to try racing. I purchased a new Losi scte 1.0 very cheap but, I am new to the electric game so I need info on a motor,esc, and the rest. Any help would be greatly appreciated.
ThinkFast8 is offline
