Ask Team Tekin
#796
Can I use a RS Pro with a Gen2 17.5RPM motor?
#797
Guys i have a question , the cooling fan for the motor , the air flow need to go direct on the motor or to the other side so they pulls the hot air to the back of the car ? Thanks !!!!!
#799
Thank You Odin !!!!
#800
Thank you Odin!
#806
1/8th nitro guy looking to get into electric touring car and i would like to know,
how come you're http://www.teamtekin.com/redline_gen2.html4.5t motor has more kv (9350 kv) then other companies 4.5t (7100-7950 kv).
#807
Well I had something fun happen to me tonight during 1/18 short course truck racing. The capacitor on the FXR simply broke off in mid heat. Went from 2nd place to DNF.
I'm wondering something. Is the ESC damaged and can't be used now?
#808
#809
Does the esc power up and work?
#810
last night when I tested it after a speed fix, it powered up and the leds flashed the init pattern, but the motor did not emit any init tones. I will however solder a different capacitor on and try again.
edit: tried a different and larger capacitor, no difference. So I looked at the motor itself. And found the culprit. Guess I blew out the windings or the comm.
