Go Back  R/C Tech Forums > Commercial/Retail Forums > Superior Hobbies
Axial AX10 Scorpion ARTR - IN STOCK >
Old 07-17-2008, 10:30 AM
SuperiorHobbies's Avatar
Default Axial AX10 Scorpion ARTR - IN STOCK
The Axial AX10 Scorpion 1/10, 4WD Electric, R/C Rock Crawler ARTR (Almost Ready-to-Run). Just add your choice of electronics, and you'll be able to hit the rocks in shorter time than having to build your entire crawler. The ARTR was designed from the ground up, and every detail was thought through to provide a competition level base kit to work with. Previously the only way to build a competition capable rock crawler was to buy bits and pieces of several different kits here'n'there. This long and sometimes frustrating process could take as long as several months just to get the right parts together before you could even start the build. Now you can get a factory built rolling chassis, and within approximately an hours build-time you'll be able to hit the rocks with your competition ready AX10 Scorpion rock crawler.
SuperiorHobbies is offline
Old 08-19-2008, 09:14 AM
