Go Back  R/C Tech Forums > Commercial/Retail Forums > Superior Hobbies
NOVAK GOAT BRUSHLESS SYSTEM - IN STOCK >
Old 12-11-2007, 11:32 AM
SuperiorHobbies's Avatar
Default NOVAK GOAT BRUSHLESS SYSTEM - IN STOCK
The specially designed Crawler motors scale over other brushed motors because of their massive start up and low-speed torque, all without sacrificing power or control. This eliminates the need to use 3-cell Li-Po packs, required by out-runner motors, which adds unnecessary weight to the rig. Novak's lightweight brushless system can tackle the most challenging terrain on 2-cell Li-Po packs.
Both Crawler motors include the same high-performance sintered rotor that Novak’s Velociti-series motors currently use. Additional features of the Crawler 18.5 Sintered Brushless Motor and the Crawler 21.5 Brushless Motor include sensor-based commutation for precise rotor position control; a high-performance sintered rotor for stronger motor braking power and improved performance in higher temperature conditions; an oversized front bearing for extra durability and extended life; ribbed aluminum end bells to reduce weight; and a solder tab system for flexible soldering options.
SuperiorHobbies is offline
