Go Back  R/C Tech Forums > Commercial/Retail Forums > Superior Hobbies
ASSOCIATED B44 - IN STOCK >
Old 11-08-2007, 02:07 PM
SuperiorHobbies's Avatar
Default ASSOCIATED B44 - IN STOCK
The Factory Team B44 project came to life in 2003 as a cooperative effort between Team Associated and J Conceptsí Jason Ruona and Brad Reelfs. After Team Associatedís Ryan Cavalieri won the 2005 IFMAR World Championships in Collegno, Italy with the BJ4 Worlds Edition, Area 51 shifted into overdrive to produce a true 'Associated' inspired 4WD buggy that would continue to dominate the 4WD off road racing class. The B44 is the result of this two-year development effort.
During the design and development stages Associated used their extensive and well-proven skills to make a 4WD competition buggy that is better suited to production. The results of this optimization are realized by you, the customer, in a more cost-effective vehicle with more readily available spare parts.
The B44 is built on a 2.5mm woven carbon fiber main chassis and top plate. Whatís new is the composite front bulkhead and rear chassis plate. These new features greatly improve overall durability and increase the ground clearance, further enhancing the B44's performance.
Area 51 designers also improved the BJ4ís slipper clutch. The result is the B44ís new externally adjustable, dual pad slipper clutch, which transfers power to the ground more efficiently and effectively.
The B44 employs a hardened steel CVA drivetrain with lightened ball differentials for unparalleled acceleration. The B44 soaks up the bumps using Factory Team hard anodized aluminum threaded shocks with gold shock shafts. The shocks mount to durable 3mm woven carbon fiber shock towers, making the B44 more responsive and giving quicker handling.
The B44 gets the full Factory Team treatment with blue titanium turnbuckles, blue aluminum shock bushings and blue aluminum servo mounts for a car that looks as good as it is fast!
Many Team Associated fans from all over the world have asked us when we are going to build a 4WD buggy. Team Associated is proud to say that day has come with the B44, the only 4WD electric race buggy that comes from a racing heritage with 20 IFMAR World Championships behind it.
SuperiorHobbies is offline
Old 12-02-2007, 07:23 PM
Jeff Brown's Avatar
Jeff Brown is offline
Old 03-04-2008, 08:49 AM
