Go Back  R/C Tech Forums > Commercial/Retail Forums > Superior Hobbies
KYOSHO LONG CHASSIS CONVERSION - IN STOCK >
Old 07-23-2007, 04:14 PM
SuperiorHobbies's Avatar
Default KYOSHO LONG CHASSIS CONVERSION - IN STOCK
25mm Longer chassis with added length in the rear increases stability because of the length and increased steering due to the weight distribution being moved forward.
New longer torque rod and rear driveshaft for the added length of the chassis.
New wing stay raises the wing and provides better down force.
New lightweight aluminum knuckles decrease weight and provide more strength. Plastic inserts for the bearings allow perfect fit and better bearing life.
New wheel nuts with nylon locking ring.
SuperiorHobbies is offline
