Go Back  R/C Tech Forums > Commercial/Retail Forums > SpeedTech R/C
Hard to get parts order >
Old 12-23-2010, 07:34 AM
Barry White's Avatar
Default Hard to get parts order
Hi can you help me find these parts?
Thanks,
Tamiya: (http://www.tamiya.com/)
49259 Tire Warmer
50638 FWD Touring Car A Parts (Gear Case)
53098 Stainless Steel Suspension Shaft Set (x2)
53112 Top-Force Aluminium Pressure Plate Set
84102 Tamiya Mascot Sticker Set
Aero Car Technology: (http://www.aerocarlubricants.com/)
AC-1001 Super Speed Gear Lube
Associated: (http://www.teamassociated.com)
#8546 M2x6 BHCS Blue Aluminium (4) (x4)
#8547 M2x6 FHCS Blue Aluminium (4) (x6)
Atlas: (www.miwahobby.co.jp)
MH7-576 Team Decals
MH8-307 (of MH8-308) Spoke Type Setting
CRC: (www.teamcrc.com)
5008 The Final Cut Truing Bit
Edit: (http://www.rc-edit.com/)
ED030032 Titanium Shock Shaft
HPI: (www.hpiracing.com)
87266 Serrated Flange Nut M4 (Silver/4pcs) (x3)
Jaad: (www.jaadracing.com)
JDRHS01BK JAAD Racing Alum VFS-1 Heatsink Black
Kawada: (http://www.kawadamodel.co.jp/)
B61M Thin-Shaped Heat Sink M
Keyence: (http://hobby.keyence.co.jp)
OP-87210 Chevalier Turbo
Ko Propo: (http://www.kopropo.com)
61003 ICS Communication Adapter
60227 KG-1 Drift
Marc Rheinard: (http://magento.p121718.webspaceconfig.de/)
Marc Rheinard Diff Grease
Much More: (http://www.much-more.co.kr/)
MR-TMCK Thermo Electric Motor Cooler
MM-RHOB CTX-M Motor Master RPM Hole Option for Modified Motor
MR-D6 Much-More Logo Decal Black On White Background
Morotech: (http://www.morotech.jp/)
BT-WBK Battery Warmer
Mylaps: (http://www.mylaps.com/)
RC4 Transponder
Niftech: (www.niftech.com)
#4710 Motor Heat Sink 1
#4715 Motor Heat Sink 7/16
R1 Wurks: (http://r1wurks.com)
Endbell Fan Kit
RC Square: (http://rc-square.com/)
SGE-920BK 2.0mm Spacer Black (8Pcs)
SR-314RB 3x14mm Hex Buttonhead Screw Black (12pcs)
SGD-4 Square Logo Decal
Speed Mind: (http://www.speedmind.net/)
GW025BK Setting Wheels
Team Orion: (www.team-orion.com)
ORI14155 TS Rocket Pack LiPo 3500 IBS (x3)
Take Off: (http://takeoff.main.jp/)
TS-381BK M3x6mm Hex Socket Button Head Screw (x2)
TS-1151 M3x6mm Magnesium Button Head Screw (x2)
TO-342BK Set Up Wheel Black
TRG: (http://www.rc-trg.com/)
TRG-5088 Servo Saver Horn Short
Xenon: (http://www.xenon.ne.jp/)
Dec-0032 Decal Black
ZX1: (http://www.team-zx1.com/)
C76 Microlube
Barry White is offline
