3000Hv help disharging
Old 04-03-2002, 08:59 PM
Default 3000Hv help disharging
Hi
I was woundering when I discharge my 3000's hv and smh what do I do with them. I have been taking them down to 5.5 volts and levign them there till next sat. At the track I do the same thing inbetween runs but put it on the tray to till the lights go out then change to get a full chage. Is this the right thing to do? I am chargiing at 5 amps with a threshold of 5 on a millenium..
THanks for your your help,
TeamAE
FOr all you tuning needs:
www.competitionx.com
teamAE is offline
Old 04-04-2002, 06:34 AM
Joel Lagace's Avatar
Drop by the SMC RACING SITE for Charging and Maintenance of your Packs.
Basically your treatment of the HV and SMH cells will be a little different. Volt thresholds are very different. .07 for HV and .02 for SMH.
Joel Lagace is offline
Old 04-10-2002, 03:34 AM
charging question:
I'm using Robitronics Pro 2K+ charger and threshold value is like 4 - 20. When you say .07 - is that .07mv or 7mv? And is that value for one cell or for the entire pack? I'm a bit confused on how to translate your T35 values (I'm assuming your using CE) into my charger's values ... please help.
stik is offline
Old 04-10-2002, 08:27 AM
Eddie M's Avatar
Exclamation
What he said is .07V delta peak for 6 cells NiCad pack. Single cell delta peak voltage is .012V for most NiCad cells
Eddie M is offline
Old 04-10-2002, 06:48 PM
thanks for the info, ed ... that would 12mv cutoff on my Robi since it's selectable value is for each cell.
stik is offline
Old 04-10-2002, 09:46 PM
Eddie M's Avatar
BTW, SMH cells has different delta peak compare to HV cells
SMH delta peak at 0.02V for 6 cells pack. So single cells detla peak is 3.33mv.
If you set your delta peak to 12mv for SMH cells then you will overcharge the pack!
Eddie M is offline
