smc lipo help!!!
Old 10-17-2008, 09:34 AM
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
Default smc lipo help!!!
i have a smc 5000 mah lipo 7.4 2 cell anyways somehow the balancing plugs have broke off not all the wires but 2 of them is there anything smc can do or do i have to pay if i have to pay how much thanks cody
sickjamminracer is offline
Old 10-20-2008, 07:35 AM
ttt
Old 10-24-2008, 09:00 PM
kenshu's Avatar
You can take a xacto knife and push the pin out of the connector and solder the wire back on.
kenshu is offline
Old 10-25-2008, 06:28 AM
well put it this way i cant see the other end of the wire so ??? i dont know what to do i am going to have to call smc and c if they will fix it and if not how much they will charge
Old 10-28-2008, 12:54 PM
ttt
Old 11-01-2008, 10:48 AM
ttt
Old 12-03-2008, 10:15 PM
If you can split the plastic outer shell without blowing your self up , the rest is easy.(with a little soldering experience)
Once the outer hardcase is removed you can carefully cut away the shrink, don't cut through cell .
once shrink is cut away you will clearly see solder on the ends of pos. and neg. lead wires
on a 2cell lipo there are three balance wires . one goes to pos. one goes to neg. third ?? ( didn't go in that far )
if you can find out which wire goes were. all you have left to do is carefully solder the lead back to the corresponding terminal.
I personally did this with a core-rc 3250Mah 2s lipo today.
Same problem red balance wire came completly off lipo cell.
Carefully removed Hard case, and shrink . Re-soldered wire . put hardcase back on ( needed a little tape to hold together. Was going to use CA , but decided against , in case this happened again )
Hope this helps. By the way SMC hardcase will be harder to remove
Probably not recommended by SMC. But is the cheapest alternative.
USE UTMOST CARE AND ATTENTION LIPO can cause fire.
bambikilr is offline
Old 12-04-2008, 05:29 PM
its a soft case and also there are 6 wires for the balance port
