Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers > Singapore For Sale-Trade
FS - Hudy Drive Pin Replacement Tool (for 3mm Pins) >
Old 04-11-2013, 10:00 PM
TaKi11's Avatar
Default FS - Hudy Drive Pin Replacement Tool (for 3mm Pins)
A "must have" item for racers of all levels, HUDY is the first to bring you a tool that will not only save you money, but will also save you precious time at the track or at home.
One of the leading causes of ill-handling cars comes from improperly working suspension caused by driveline binding. In cars of all scales it is important to check and regularly replace the drive pins before they wear flat. A worn pin can cause inconsistent handling and poor overall performance. It is well known that drivers in the past have gone to great lengths to either replace their pins frequently or incur the cost of replacing the compete drive shaft.
The new compact, heavy-duty HUDY #10 6000 tool set will allow you to quickly and easily change worn pins in a matter of minutes.
Letting go @ $90
CALL/SMS @ 90 275 270 (SELF COLLECT AT WOODLANDS)
Riversails, DUO
TaKi11 is offline
Old 04-23-2013, 02:28 AM
TaKi11's Avatar
TaKi11 is offline
Old 05-08-2013, 10:46 PM
TaKi11's Avatar
TaKi11 is offline
