Feedback on FUTABA 3PK
I've tried using Hitec digital servos with the HRS receiver and it's working fine. I don't have any KO digital servo so cannot confirm compatible or not. You might want to try it out on the KO servos.
I heard from Kenneth that this super duper radio can send SMS, MMS and is also a PDA rolled into one..............
is it heavy? cos it looks kinda bulky
I tried the 3PK just before the Expo race, and well uh... found the handling and feel about the same as my 3PDF. Both weight in about the same too! So for now I'll stick with my 3pdf.
Ozone: Very scary siah. Phantom was besides me with the earphone attached to the TX!
Is it already available in SG? Where can i get one? How much is it for the tx and rx only? I heard the response speed is amazing
eh.....
I heard someone tat the 3pk high speed respone reciever cannot use normal servo or else dunno the servo or the reciever will burn izzit????if u use the normal reciever noting will burn.....
Yah Kenneth, didn't you program the secret button at the hand grip to clock your car speed?
You're right on that Stratuskyo, you cannot use normal servo with the HRS receiver because the manual said it will cause fire hazard. The PCM receiver is ok for normal servos but 3 times slower in response speed.
wun lah...
wun burn up ur electronics...
but from wat i know,2 use the high-speed response function,it will have 2 be used wif a futaba digitial servo,not sure if making it up with other brands of servo will work...
i think the 3pk is available at tai sing at tis moment...
3pk selling at rm1700 in kl..
Comes with pcm receiver + 2x 9451 servos..Do you guys know the servo spec?
Btw only 27mhz available now..
camera???
Heard that this super duper controller have a build-in digital camera is it? And i saw phantom use it on his first EP race. Taking shots and talking to the control, and still came in 2nd in B main. Is it the controller or is the driver that is good?///????
