Rally, Drifter, EP & GP
#16
huffy: what is your system status now?
Mine is RTR (Ready to Rally)....
Testing tyres n setup now......(not much there to set anyway)
#18
I lend u my MC230R how?......but please dun run with speedgem OK?
doesn't seem right to run the 'intermezzo' alone...everytime my car got bashed
pass u if you want this wed....along with the MK2 hehehe OK? paiseh
#19
mk2?
im not sure how to tune engines leh.....better safer if leave that to my brother..haha..or if u bring ur mk2 to ms..the other drivers at the track would help u...mine is tuned by one of them..but i lost the settings already...my engine is a little screwed now.
hehe 230 with stock engine can right?
btw i hope ur 230 still uses normal connectors..
i hav 2 packs of 1400mah cells..how many amps shall i charge them at ?i dare ot plug them into my charger unelss someone can confirm that it is save to do so..lol
#20
yep....mk2.
i also lost the setting oredy...last time was fine just need to patch the electronics in, now oooh like want to blowup like that.
Anyway, 230 is for stock motor...you can modify the cables to match yours...as long as you take good care of it...OK lah.
Charging 1400, maybe you need to discharge them first...cool it then charge it at rate of 0.7-1 A should be Ok, just keep it away from heat....let the fan runs.
#21
wah..if charge at 1 amp..1 hr then can ar..
i got this cheapo charger i use to charge them..45 mins..but it gets SUPER HOT
aiyo..mus chg plugs ah..not usin tamiya + bullet connectors?
oh to chg ur idle rate tat one quite easy..but set the air fuel mixture thing i dono ...
#22
nvmd.....do the best u or ur bro can,...I dun expect much lah..
Can run, controllable, OK redy.
If it is superhot it is possible that u overcharge it....the cheapo charger might not be of delta peak detect kinda charger rite?
use your EX pro loh...
#24
Hi guys, me new in rc, but very into rally car. So where to run rally in singapore?
#25
RR: I use to play at open soccer field, hard flat and dusty, the best. Not those with grass or too bumpy (can't get the speed effect). So far, not many ppl into rally....in fact none in this thread except me.... I'm rally maniac hehehe
Other place to play is tarmac, carpark with hump....smooth surface more grip and jump...
Proper track....none that I've known of.
Do you RC Rally?
Do you RC Rally?
#27
Hey all drifter, I got a Kyosho pure 10. Anyone wanna exchange or how much you think my GP car can fetch - lelong! lelong! I would like to see and join a drifter club, but a little against Nitro, prefer EP, SAVE THE PLANET........ GTO help leh, let me join u guys. Budget tight. Now current Team Epic, later TXT and now thinking EP drifter...Sigh.....You all really bad influence! I think my mon gonna ask me to stay away from u guys!!!!
#28
Originally posted by HuFFy
hey GTO..u got an evo 3 TL-01?
mines an evo 4 ...we can start some evo club or something..hah
anyway hope to get it up and running!
I got mixed up lah...actually it's EVO IV but I planned to down grade it to EVO III GSR...hehehe
Anyway, u still need me lend u the ESC ? this Sat loh...k? N also pass u/ ur bro the MKII Rx....
#29
