Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
RaceWorks OnRoad Bash 2013 - Club Races >
Old 01-27-2013, 07:15 PM
RaceWorks's Avatar
Default Registration for RaceWorks OnRoad Bash 2013 (Club Race)
RACEWORKS ON-ROAD BASH 2013 - CLUB RACE 1
Make history and be among the first to race on RaceWorks' new onroad circuit !
Date: Sunday, 3 Feb 2012
Time: From 1pm onwards.
Venue: RaceWorks Arena, Bottle Tree Park - NEW ASPAHLT ! NEW LAYOUT !
Fee : RaceWorks members - $10 per class / Non-members - $15 per class
Rental transponders will be available at $5 per transponder
Trophies: Trophies will be awarded to the A-main top-3 and 1st in lower finals only
Please note
The maximum number of participants for all 3 classes combined will be 50. So please register and make payment early to secure your entry.
Classes / Rules
A) Novice OnRoad "Breakout" Class (Max 10 entries)
Chassis: Open (Onroad chassis only eg Mini / 4WD TC / FF / F1)
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Min lap time: A minimum laptime will be imposed for this class. We will set this tentatively at 21 secs (subject to final adjustments on raceday depnding on the types of entries we have). Laptimes clocked faster than the min laptime will be rejected
B) 17.5T Blinky Class (Max 20 entries)
Chassis: Open to all TC
Motor: Open to all brushless motors that are not lower than 17.5T.
ESC : Open to all ESCs capable of running in the no-boost / “blinky” mode. The no-boost / blinky mode must be used for this class of racing.
Gear ratio : Open
Battery : Lithium Polymer 2S hard case 7.4v battery pack.
Min Weight : 1400g
Bodyshell : All 190mm TC bodyshells. The rear wing including endplates must not extend higher than the roofline
Tires : Sweep Pre-Mounted Tires. Tires must be purchased from RaceWorks Hobbies.
C) 13.5T SuperStock Class (Max 20 entries)
Chassis : Open to all TC
Motor : Open to all brushless motors that are not less than 13.5T
ESC : Open to all ESCs. Boosted / turbo mode may be used.
Gear ratio : Open
Min Weight : 1400g
Tires : RIDE Revolution (Re36) High grip belted tires with wheels. Tires must be purchased from RaceWorks Hobbies.
Race Format
Qualifying : 2 x 5min rounds. Best 1 of 2 rounds to count. An additional round of qualifying may be run depending on the number of entries (in which case, the best 1 of 3 or best 2 of 3 IFMAR format may be used to sort racers for the finals)
Finals : 2 x 5min finals. Best 1 of 2 finals to count. ROCS tiebreak format will apply in the event of ties.
Please register below
Novice Open "Breakout" Class
Name / Car / Freq / PT#* / RaceWorks Member (Yes/No)?
*Personal Transponder (if you need to rent a house transponder, please indicate "rental")
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
RaceWorks is offline
Old 01-27-2013, 07:24 PM
HoJo's Avatar
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
1. Dominic Quek / Xray T4 / 2.4 / 2292301 / RW (Paid)
2.
3.
4.
5.
6.
7.
8.
9.
10.
HoJo is offline
Old 01-27-2013, 08:49 PM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
2. Daryl Thong / Xray T4 / 2.4 / 2534753 / RW
3.
4.
5.
6.
7.
8.
9.
10.
Valinor is offline
Old 01-27-2013, 09:09 PM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
1. 667 - Joel / Xray / 2.4Ghz / TBC / TBC
2. 667 - Daven / AE / 2.4Ghz / TBC / TBC
3. 667 - Mark / AE / 2.4Ghz / TBC / TBC
4. 667 - Ken / AE / 2.4Ghz / TBC / No
6. 667 - Winston / Serpent / 2.4Ghz / TBC / TBC
7. 667 - Stephen / AE / 2.4Ghz / TBC / TBC
8. 667 - Bernard / ARC / 2.4 Ghz / TBC
9. 667 - Yiming / Xray / 2.4Ghz / TBC
9. 667 - Daniel / Xray / 2.4Ghz / TBC
10
3.
4.
5.
6.
7.
8.
9.
10.
ammo is offline
Old 01-27-2013, 09:47 PM
3.141592's Avatar
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
10
3. P.Y.Tang / Xray T4-Orca / 2.4 / 4146804
4.
5.
6.
7.
8.
9.
10.
3.141592 is offline
Old 01-27-2013, 10:05 PM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
10 Juno / Xray/ 2.4Ghz /rental / Yes
4.
5.
6.
7.
8.
9.
10.
Chelsea128 is offline
Old 01-27-2013, 10:26 PM
stormviper30's Avatar
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
11. Alan Cher / TRF417X / 2.4Ghz / 2192505 / No
4. Alan Cher / TRF417 V5 / 2.4 / TBC / No
5.
6.
7.
8.
9.
10.
stormviper30 is offline
Old 01-27-2013, 10:38 PM
17.5T Blinky Class
12. Chad / ARC / 2.4Ghz / rental / No
13. Cameron / ARC / 2.4Ghz / rental / No
cboerst is offline
Old 01-27-2013, 10:40 PM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
5.
6.
7.
8.
9.
10.
TRF 417X / TRF 417V5 / TT-01E
Orca Spark / Orca RX2 / Futaba 4PKS
cboerst is offline
Old 01-27-2013, 10:57 PM
Moderator
BloodClod's Avatar
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
5. BC / t4 / 2.4 / tbc / rw
6.
7.
8.
9.
10.
BloodClod is offline
Old 01-27-2013, 11:46 PM
HoJo's Avatar
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
1. Joel / Xray / 2.4Ghz / TBC / TBC
2. Daven / AE / 2.4Ghz / TBC / TBC
3. Mark / AE / 2.4Ghz / TBC / TBC
4. Ken / AE / 2.4Ghz / TBC / No
6. Winston / Serpent / 2.4Ghz / TBC / TBC
7. Stephen / AE / 2.4Ghz / TBC / TBC
8. Bernard / ARC / 2.4 Ghz / TBC
9. Yiming / Xray / 2.4Ghz / TBC
9. Daniel / Xray / 2.4Ghz / TBC
14.
15.
16.
17.
18.
19.
20.
6. Nicholas Lee / TRF417v5 / 2.4 / TBC / RW
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
HoJo is offline
Old 01-28-2013, 04:46 AM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
14.
15.
16.
17.
18.
19.
20.
7. Barbie Yong / Xray T4 / 2.4 / TBC / RW
8. Colin 'The Monster' Tong / TRF417V5 / 2.4 / TBC / RW
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
kamenkoh is offline
Old 01-28-2013, 07:54 AM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
14. Teh Zi Sheng / TA06 / 2.4 / rental / No
15. Jonathan Ho / T4 / 2.4 / 4145500 / No
16.
17.
18.
19.
20.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
frozenfireex is offline
Old 01-28-2013, 07:06 PM
kansai's Avatar
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
6. Stephen / AE / 2.4Ghz / TBC / TBC
7. Bernard / ARC / 2.4Ghz / TBC / TBC
8. Winston / Xray / 2.4 Ghz / TBC
16.
17.
18.
19.
20.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
kansai is offline
Old 01-29-2013, 08:18 PM
Please note
Classes / Rules
Motor: Open
ESC: Open
Battery: Open
Bodyshell: Open
Tires: Open
Gear ratio : Open
Min Weight : 1400g
Gear ratio : Open
Min Weight : 1400g
Race Format
1.
2.
3.
4.
5.
6.
7.
8.
9.
10
17.5T Blinky Class
3. Ken / AE / 2.4Ghz / TBC / No
4. Stephen / AE / 2.4Ghz / TBC / TBC
5. Bernard / ARC / 2.4Ghz / TBC / TBC
6. Yiming / Xray / 2.4Ghz / TBC
7 Juno / Xray/ 2.4Ghz /rental / Yes
8. Alan Cher / TRF417X / 2.4Ghz / 2192505 / No
9. Chad / ARC / 2.4Ghz / rental / No
10. Cameron / ARC / 2.4Ghz / rental / No
11. Teh Zi Sheng / TA06 / 2.4 / rental / No
12. Jonathan Ho / T4 / 2.4 / 4145500 / No
13.
14.
15.
16.
17.
18.
19.
20.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
ammo is offline
