Battery Questions
Battery Questions
hi. would like to know the Voltage ratings and Amp ratings for these
Modes below
Discharge Rate
Voltage rating? Amp rating?
Balance Rate
Voltage? Amp?
Storage Rate
Voltage? Amp?
Need to know them please do help me thx in advanced
heard alot of theories but i wan know actual safe zone ratings
Modes below
Discharge Rate
Balance Rate
Voltage? Amp?
Storage Rate
Voltage? Amp?
For lipo batt, below are the recommendation.
Discharge Rate
Voltage rating - (set to the no of cell as the the batts i.e. 1S, 2S, 3S & etc)
Amp rating - 1C (most charger can only do 1 Amp, some can do up to 10 Amp, i all depends on your charger)
Balance Charging Rate
Voltage - (set to the no of cell as the the batts i.e. 1S, 2S, 3S & etc)
Amp - 1C ( you can set to more than 1 C (some lipo can do up to 5C), however higher C charging will reduce Lipo batt life)
Storage Rate
Voltage-(set to the no of cell as the the batts i.e. 1S, 2S, 3S & etc)
Amp 0.5 to 1 C (Lower C will prolong the batt life)
Above are just recommendation. Some my use higher C for charging & discharging but in general higher C charging will shorten batt life.
Discharge Rate
Storage Rate
