what motor is this?
Old 06-23-2002, 12:04 AM
bigbutstupid's Avatar
Default what motor is this?
its a tamiya motor
called dyna-run
the can is black in color...
can anyone give me the specs of this motor?
bigbutstupid is offline
Old 06-23-2002, 04:15 AM
Alvin's Avatar
Black can? Odd.
Got 2 variants afaik: Dyna Run Super Touring which is a 13x2 modified motor. Dyna Run Stock Racing which is a 27x1 (supposedly).
hths.
~Alvin
Alvin is offline
Old 06-23-2002, 04:26 AM
its quite old liao
now i never see it on market
and not even on tamiya site
Old 06-23-2002, 04:33 AM
Alvin's Avatar
http://www.tamiya.com/english/rc/rci...ts/mini141.htm
Alvin is offline
Old 06-23-2002, 04:37 AM
it looks like the one on the left
should be la
tamiya onli produce these two isit?
how many T is that?
Old 06-23-2002, 04:48 AM
Alvin's Avatar
as mentioned above, it is a 13x2.
Alvin is offline
Old 06-23-2002, 11:59 PM
ijnek's Avatar
Smile
r u talking abt the old tamiya motor?...black in colour and cannot change the brushes???...
if tat's the 1,then it's a 18000 RPM super stock motor.dunno abt the turns...
ijnek is offline
Old 06-24-2002, 01:19 AM
Hi Alvin, Mr Mit.
Just wondering, how do you know it;s 13x2? Did you read or unwind it to count or estimate?
thank you
Kasey is offline
Old 06-24-2002, 01:52 AM
imataquito's Avatar
heheh dyna-run a 13x2??? how do u know ?
compared with a atlas 13x2 its VERY VERY SLOW !
imataquito is offline
Old 06-24-2002, 02:02 AM
Alvin's Avatar
Kasey: I found the info from the www.tamiya.nl website, I don't seem to be able to find it again. A quick web search showed this:
http://home1.stofanet.dk/franks_mrc_...e/TAMotor.html
http://www.tamiya.nl/tamtam/regels/2002nk_treg.html (First colum, under 4WD Super Sport)
http://users.pandora.be/tamiya.belgi...atio's.htm
Also, the setting sheets for the various tamiya vehicles at the tamiya netherlands site also put it at 13x2, if I am not mistaken.
imataquito: Didja gear it properly? I tried a DRST on a tb-evo, it is a very very torque-ky (sp!) motor.
Alvin is offline
Old 06-24-2002, 02:05 AM
ijnek's Avatar
Smile
jus thought this question of mine might b sled some light here...
does 2 different motors but with the same spec such as 13x2 have the same performance???...
ijnek is offline
Old 06-24-2002, 05:42 AM
That's right , it's a 13x2. Mel and i cut one out to count back in the year 2000, Sembawang days ...... The performance is much milder compare to other brands. We didn't expected it to be 13turn !!! But that's true.
Rotor lamination, wind style - pattern wound, solder blazing, actual coil thickness make the difference on the armature part.
Magnet strength and can design make the other half difference.
End bell(dammmper system) also contributes.
Brush and comm cut also.
SSOOO 13x2 means alot if the manufacture are different. The only way to tell is to put is on a motor DYNO - watts, max effc, torque ...... are so of the data you can use to determine which is better.
Kasey is offline
Old 06-24-2002, 05:53 AM
i'd like to ask, how come the motors available nowadays are shorter in length than the tamiya 540 ones? doesn't that make it weaker?
huasze is offline
Old 06-24-2002, 06:23 AM
imataquito's Avatar
huazhe: ??????????????/
alvin i geared it at 6.28 and 6.87 for the DYNARUN tourer if i remembered it correctly
still SLOW
iknek no........ i ahve seen a 12 turn machine wound move much slower then a hand wound one ... both brand new and broken in ... and used by a very experienced racer ( in SEREMBEN )
his fav motor ?
a 7 turn double and he broke his pro 3 with it ...... HA HA HA
Old 06-24-2002, 07:28 AM
Alvin's Avatar
Kasey: Wah liao, next time you guys gonna do something like that, give to me! My 11x2 you saw that day, KO'd in the 3rd heat so I went back to my trusty Trinity speedgem 14x2.
Huaze: If you are comparing the motors which come in the kits, remember that comparing those to say a Type T, the type T's brushes can be seen and changed, whereas the Mabuchi's brushes are closed up inside, hence it seems longer?
imataquito: Haven't seen you in the forums for so long! How is your tamiya chassis so far? What about the motor timing? The stock dynarun timing is like 1mm? Very little. Maybe you can try upping it a bit more? What about the brushes? Have you ever tried it with dual shunt brushes? hehehe
Alvin is offline
