Help!!! Hitech CG-335Charger
can this charge Ni-Cd and Ni-Mh at the same time?
wat's the main difference between the 2 type of batteries beside the duration... btw is the difference between the duration of usage and charging big or not too big?
can i charge the receiver and transmitter packs with this
would be better if you were to use it to charge tx and rx pack. can use it to charge glow heater too. dun advise using it to charge sub c cells. However do not really know if can use to charge nimh because dun seem to have function to control delta peak.
