12v
Old 05-03-2002, 08:38 AM
Default 12v
i need help from guys that i want to buy one 12v. But i don't konw how many amp to buy.
Apollo^Guy is offline
Old 05-03-2002, 11:13 PM
What 12V? Battery for box starter or power supply for the charger? If power supply advised to get minimum 8amp. If battery, 7amp.
Rose Money is offline
Old 05-04-2002, 12:53 AM
Alvin's Avatar
Recommend you get a Gel-Cel (more expensive VS lead acid but more easy to handle), > 50Ah. I have a 40Ah battery, not bad pretty heavy when bring to races though.
Alvin is offline
Old 05-05-2002, 04:49 AM
ijnek's Avatar
Smile
i presume that you are talking abt power supply bcos battery do not go by Amp as their rating...
tat would depend on the type of charger or watever u r going 2 use.different chargers have different ratings,the best would be 2 buy a charger which will provide the charging current slightly above the needed current 2 charge the battery.
eg...
LRP quick charger has a rating of 4Amp,so a power supply slightly above 4Amp would b good such as 5Amp,...
but some digitial chargers have a range,so anything within the recommanded range would b good.
hope tis is of benefit 2 u...
ijnek is offline
Old 05-05-2002, 05:05 AM
Alvin's Avatar
Batteries DO have a ampherage rating. They are rated at Amphere-Hours. So our 3000mAh cells (equals 3Ah) are good for powering a 1 amphere item (say a fan which pulls 1A) for 3 hours.
Alvin is offline
Old 05-06-2002, 06:39 AM
ijnek's Avatar
Smile
hmmm,...
is tat so?...thanx for the adv...
but i thought there is a different unit to calculate the capacity of batteries,...
ijnek is offline
Old 05-06-2002, 05:53 PM
Buy a genset... it cost abt $400 and gives you 50A and u can use it to watch TV at teh same time, and last up to 8 hrs...:P
Madman is offline
