Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Street jam OTA-R31 chassis >
Old 08-19-2011, 09:30 PM
  #181
boolean21's Avatar
Originally Posted by RTECH
If still cannot , bring your ota to me.
ok man!
boolean21 is offline
Old 08-21-2011, 08:59 PM
  #182
Default pulley solution
you cant do over a 39/18 pulley for short belt.
anything bigger wont fit on belt.
use.
39/16
22/14
39/18
equals 77%
or
39/15
21/14
39/18
equals 80%
good to start with and can get using CS pulleys
digi16v is offline
Old 08-22-2011, 04:08 AM
  #183
RTECH's Avatar
use.
39/16
22/14
39/18
equals 77%
or
39/15
21/14
39/18
equals 80%
39/19 still can use the short belt . You need to switch the hex bearing holder to the correct position.
RTECH is offline
Old 08-22-2011, 10:10 AM
  #184
boolean21's Avatar
use.
39/16
22/14
39/18
equals 77%
or
39/15
21/14
39/18
equals 80%
thanks all...
will try it out soon...
hmm, i got one white pulley... i think came with the cs pulleys.... is that supposed to be the 36t big pulley for the rear? i can't find any numbering on the pulley... and i havent go count the teeth... :P
Old 08-23-2011, 04:14 AM
  #185
RTECH's Avatar
Originally Posted by boolean21
thanks all...
Yes, if the big pulley is 36t, it is for the rear.
RTECH is offline
Old 08-23-2011, 04:31 AM
  #186
boolean21's Avatar
k man... will count the teeth later!
Old 08-23-2011, 08:46 PM
  #187
too tight for my taste even if you switch hex.
still its all up to the builder...
have fun
digi16v is offline
Old 08-23-2011, 08:52 PM
  #188
boolean21's Avatar
hmm.... how to remove the big pulley to change the pulley?
need to "force" ?
Old 08-24-2011, 04:07 AM
  #189
RTECH's Avatar
need to "force" ?
There is a long allen key screw inside the "cups". Loosen it to remove the big pulley.
RTECH is offline
Old 09-23-2011, 07:45 PM
  #190
gashuffer's Avatar
Trader Rating: 48 (100%+)
have fun
+1 39/18 is the biggest you can go. 19 is very tight and puts stress on your rear drive.
gashuffer is offline
Old 09-23-2011, 07:49 PM
  #191
boolean21's Avatar
Thanks bros.... Should have time to do it up next week...
Old 11-07-2011, 10:09 AM
  #192
ftorres's Avatar
Hi bros,
Been facing this problem with the OTA R31: front steering rack seems to be vibrating when turning no matter how much I grease those parts which have to be greased. anyone has any idea how to solve this? does aluminium wheel hubs play a part in this?
btw, anybody has a good servo to recommend? preferably a high response one. I understand that KO Propo has different versions. anyone can guide me on this?
ftorres is offline
Old 12-12-2011, 12:45 AM
  #193
ftorres's Avatar
hi,
just wondering if you guys have any feedbacks of body shells not fitting nicely into the R31 chasis?
I have some difficulty fitting in the HPI Rx7 body shell
ftorres is offline
